That Tomcatter patch is the original from WWII. Lot of history behind that little patch. :)
fpv for general aircraft use
I really want to run the flight line p38 the same way. All my planes can be quickly converted from FPV to line of sight as quickly as changing the canopiesComment
Here are videos from the pby, and Seawind:
I'll echo everyone's youtube comments. Wow! That was a really great video. Well edited with all the camera shots. The "BRRRRRT!" was awesome! And, great music too. Great work! :Cool:Comment
Hey guys I did a couple videos on the Mobius and latency tests and how it compares to a real board cam for FPV use. I've posted them all here for you to have a look at. This should help clear some things up.
How to set up the Mobius for FPV
Mobius FPV Latency Test
Board Cam Latency test vs Mobius results.
I love this form of flying - scale FPV. Here are links to videos of some of the scale FPV cockpits I have built, in flight. These all started out as standard Dynam and FMS airframes, all of which either still are or have been in the MotionRC range. I just put in scale cockpits and the FPV gear. Dynam Hawker Hurricane, Dynam Albatros DVa, Dynam Tiger Moth, FMS P51b and FMS Fox glider.
5 PhotosComment
Hello RB and welcome to the Squawk,
Very impressive level of cockpit detailing which gets bumped to the insane level with the FPV and pilot joystick movement:Cool:Warbird Charlie
Great to have you on the Squawk, Robo! I've been a fan of your videos for a while. You've really got some nice setups. Keep up the great work! :Cool:Comment
RoboBiggles cockpit realism is the pinnacle of RC scale FPV. Tough act to follow.
Still, I love flying HD FPV with headtracking to explore our club field from airborn perspective. Our ground bound club members don’t know what beautiful sights they are missing; the creek for example. It’s becoming harder and harder to stay within our field boundaries....
FPV proximity & aerobatic flying "aboard" E-flite Splendor pattern plane at OCMA, Bob Swenson Memorial Field. Successfully flew under tree arch paying homage...YouTube: https://www.youtube.com/user/motionsic
Instagram: https://www.instagram.com/fpvaircombat/channel/Comment
Testing integration of DJI Ocusync Air Unit headtracking system in Avios Spitfire. Flown using visual line of sight while "passenger" takes a joyride - weari...Last edited by Turbinefancy; Apr 12, 2019, 02:46 AM.YouTube: https://www.youtube.com/user/motionsic
Ok. It took several batteries of taxiing on the ground, just to get used to “sitting in” the Spitfire cockpit. With the nose pointed high and obstructing forward view, I have to look from side to side and adapt zig zag taxing, just like full scale, to avoid patches of long grass on our runway.
Finally worked up the courage to fly from take off to landing under FPV. Even had a short encounter with my son’s LOS flown PZ Corsair. It’s a exhilarating flight. Very challenging, landing wasn’t pretty but I got it down in one piece. I am hooked to scale FPV. Looking forward to become proficient flying the Spitfire “from the cockpit” this season and hopefully do more formation and dog fight sessions.Scale FPV sunset flight in Avios Spitfire looking through world's smallest reflector gun sight (US Navy Mk 8 style) with head-tracking DJI Goggles RE. Brief ...YouTube: https://www.youtube.com/user/motionsic
Trying to get started with some FPV.
I'm running into an issue of needing a UVC driver for the Andriod tablet or smart phone.
Time to update the tablet anyway. Its an older RCA, very cheap one.
I want to initially just mount the camera and capture on the tablet or phone. Get some video to look at to see what I SHOULD see when flying in LOS and not crossing out of our flight area. Also what a good landing approach should look like.
Maybe re-aim the camera before going to goggles...
Then I want to do my capture on the tablet or phone because they can use higher capacity SD cards.
Goggles and camera work and I can drive my old Tamiya Frog in the yard with them.
Any recommendations for a tablet that WILL work with the little USB 5.8 ghz receivers?FF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
fhhuber,
I don't have an answer for your question. But I suspect your FPV solution may have too much latency to fly from the cockpit in real time. While your FPV solution may work for a ground vehicle moving relatively slow in the yard, a 0.1 or 0.2 second latency means the plane has already traveled several feet before you even see it on screen. Ok for straight and level sight seeing flight. Not ok for maneuvering or landing the plane. So for just recording a flight to get used to seeing the sight picture (very smart move), that's great!. Do you know the glass to glass (from camera to screen) delay of your system?YouTube: https://www.youtube.com/user/motionsic
