Hi Steve,
The same secondary amp works with the ASPIRE, with a couple of connector modifications. If you have one from the V4.1, I can walk you through it. If not, I am assembling pre-wired versions for the ASPIRE. I will be talking with Tom, and I am sure he will carry them on Motion. :)
The output is true stereo, putting out independent channels to each speaker. Right now there is no plan to have one sound for a TT-25, and another for a Bass, that would be a complex undertaking, plus not everyone may run the Bass. On twin engine airplane sounds, they will have separate start ups and shut downs from each channel. The RPM sound will also be mixed in a way that the tone is slightly different, so it gives a truer twin engine sound.
I have not fully decided on a digital download yet. It is possible. The card is capable of holding 10 sounds at the moment, and it comes with 10. Which means you would need to back up some, and replace them with the downloaded ones. The other option, which is the way I am leaning, is to do 'packs' like the V4.1. They will come pre-installed on a micro SD.
I don't have the manual up on the web page yet, something I need to do. Just so many things going on. :) If you can give me your email, I can send it to you.
Andrew
Andrew
.png)
