Spektrum NX8
  • telejojo
    • Jul 2026
    • 9
    Spektrum NX8
    I programmed reverse thrust on my 70mm Viper an switch g position 1.The next flight it may be on position 0 or 2 you never know where it's going to be the next flight what's up with that.
    • 8835
    Can you elaborate what kind of RX you're using, which channel on the RX you have the single reverse wire plugged into? For now, here's a guess ................................
    1. Is the reverse wire plugged into an otherwise unused channel?
    2. Is the reverse wire plugged in such that the single wire is the "signal" wire and NOT plugged into the "ground" pin?
    3. Did you go into "channel assign" in the system menu to tell it you want switch G to control the channel you have the reverse wire plugged into?
    4. If you use reverse on one flight and then go and pick up the plane where it stops and do not put the switch back to forward, the next flight, it defaults to forward even though the switch is in reverse.
      • 7437
      I'd run the update from Spectrum. You'll go from an NX8 to an NX8+ for free, got to like that, it might help.
      Here's some guidelines, I followed this and upgraded a friends NX8
      (Dangerous Dan)
      • kallend
        • 1877
        Most common cause of this kind of behavior is that you have inadvertantly got more than one input into the reverse thrust channel.
        Post your NSPM file, then we can look at what you did.
        • telejojo
          • Jul 2026
          • 9
          I did it with the transmitter when you hold the sticks a certain way to get into the programming
            • 8835
            That is "forward programming". Programming the ESC is a different menu item and different stick movements.
            However, this ONLY works IF you have a Spektrum smart Rx AND a Spektrum smart ESC (or compatible equivalent). You never said what you have, so hard to give a proper comment.
            • kallend
              • 1877
              How do you expect people to assist you if you don't answer the questions they ask?
              • telejojo
                • Jul 2026
                • 9
                It’s avion esc and nx8+ transmitter you don’t have to go through forward programming to get to the menu.Reverse works fine it’s just moving around on the switch
                • kallend
                  • 1877
                  What does the channel monitor show for the reverse channel? Does it "move around" too?
                  Either give a much more detailed description of exactly what's happening, or post the NSPM file and we can take a look at it.
                    • 5426
                    Sounds like the switch assignment is moving not the channel itself. A NSPM file would be a big help.
                    • telejojo
                      • Jul 2026
                      • 9
                      NSPM? I have no idea what that is
                      • kallend
                        • 1877
                        They are the model files mentioned on pages 29-31 of the user manual.
                        You can find out more about them by Googling "Spektrum NSPM file"
                        If you post your NSPM file for the model then others can load it into their transmitter and see what's going on and maybe help you.
                        • telejojo
                          • Jul 2026
                          • 9
                          G is a 3 position switch from what I've found it's the nature of the beast it's just going to move around.Is there a way to put it on the bind swirch or button?
                            • 8835
                            I use a 3-position switch for reverse all the time on all kinds of planes, with all kinds of ESCs and different RXs. In my case, it's switch E. You just don't stop in the middle position (1) because it doesn't recognize it as any particular function insofar as reverse is concerned. So no, it is NOT the nature of the beast. You have yet to say what receiver you are using. Is it a Spektrum smart RX? Which one? If that's the case, then you assign a switch in Avian programming (not forward programming) and go through various menu pages to get to it. Then you have to "SAVE" it.
                            You're not telling us the whole story of what's going on with your situation. As such it's very hard to come up with help. Like others here, I give up. Unsubscribing.
                            • telejojo
                              • Jul 2026
                              • 9
                              I think its a 630 new with as3x and safe I programmed reverse in avion prog and then assigned it a switch G reversed or towards will not be in the same position the next flight. On the same switch but not the same position
                              • kallend
                                • 1877
                                4th and last time of asking: If you post your NSPM file for the model then others can load it into their transmitter and see what's going on and maybe help you.
                                Switch positions do NOT move around randomly. Somehow you have managed to program an extraneous input into the reverse channel.
                                • telejojo
                                  • Jul 2026
                                  • 9
                                  You know what I’m going to do is inhibit the switch and forget it f&&&k it I don’t need it that bad
                                  • kallend
                                    • 1877
                                    I see no point in trying to help people who refuse to help themselves.
