I programmed reverse thrust on my 70mm Viper an switch g position 1.The next flight it may be on position 0 or 2 you never know where it's going to be the next flight what's up with that.
Spektrum NX8
Can you elaborate what kind of RX you're using, which channel on the RX you have the single reverse wire plugged into? For now, here's a guess ................................
1. Is the reverse wire plugged into an otherwise unused channel?
2. Is the reverse wire plugged in such that the single wire is the "signal" wire and NOT plugged into the "ground" pin?
3. Did you go into "channel assign" in the system menu to tell it you want switch G to control the channel you have the reverse wire plugged into?
4. If you use reverse on one flight and then go and pick up the plane where it stops and do not put the switch back to forward, the next flight, it defaults to forward even though the switch is in reverse. -
That is "forward programming". Programming the ESC is a different menu item and different stick movements.
However, this ONLY works IF you have a Spektrum smart Rx AND a Spektrum smart ESC (or compatible equivalent). You never said what you have, so hard to give a proper comment.Comment
What does the channel monitor show for the reverse channel? Does it "move around" too?
Either give a much more detailed description of exactly what's happening, or post the NSPM file and we can take a look at it.Comment
They are the model files mentioned on pages 29-31 of the user manual.
You can find out more about them by Googling "Spektrum NSPM file"
If you post your NSPM file for the model then others can load it into their transmitter and see what's going on and maybe help you.Comment
I use a 3-position switch for reverse all the time on all kinds of planes, with all kinds of ESCs and different RXs. In my case, it's switch E. You just don't stop in the middle position (1) because it doesn't recognize it as any particular function insofar as reverse is concerned. So no, it is NOT the nature of the beast. You have yet to say what receiver you are using. Is it a Spektrum smart RX? Which one? If that's the case, then you assign a switch in Avian programming (not forward programming) and go through various menu pages to get to it. Then you have to "SAVE" it.
You're not telling us the whole story of what's going on with your situation. As such it's very hard to come up with help. Like others here, I give up. Unsubscribing.👍 1Comment
4th and last time of asking: If you post your NSPM file for the model then others can load it into their transmitter and see what's going on and maybe help you.
Switch positions do NOT move around randomly. Somehow you have managed to program an extraneous input into the reverse channel.👍 1Comment
