My Tiger Moth Paint job
  • doctormike
    HobbySquawk Moderator
    • Oct 2013
    • 1260
    • Santa Fe NM
    I used Krylon spray paint. I copied this from a full scale T.M. Doc
  • Rocketeer
    • Feb 2014
    • 1356
    RE: My Tiger Moth Paint job
    Greetings Doc,
    Looks fantastic!!
    Best of luck,
    Bill L.
    In Okla.
    • XF-15DCC
      • May 2015
      • 164
      • Bristol CT
      That was done with rattle cans?
      WELL DONE!!!!!
      Kevin
      Off with one helluva roar!
      AMA 1085465
      • CT
        • May 2014
        • 294
        Originally posted by doctormike
        I used Krylon spray paint. I copied this from a full scale TG. Doc
        Outstanding!! How did you faux finish the prop.?
        Chris
        • doctormike
          • Oct 2013
          • 1260
          • Santa Fe NM
          Chris
           I balanced it first. I rubbed it with alcohol, then sanded it with 600 grit paper. I sprayed it with Krylon Bauhaus yellow. After it was completely dry, I used a brown sharpy marker to mark lines the length of one blade at a time. I then lightly sprayed alcohol onto a piece of paper towel and LIGHTLY rubbed the length of the blade. Experiment with the amount of alcohol and how you rub it. If you don't like what you've done, alcohol will remove the marker, and you can try again. Have fun! Doc
          [hr]
          WELL DONE!!!!!
          Kevin
          Thanks! Doc
          • farmflyer
            • Mar 2015
            • 1164
            • Quitaque Texas
            Wow nice job it looks like a completely different plane.
            • SOB8604
              • Dec 2014
              • 163
              Sharp looking scheme! Well done!
              • Capt. Crunch
                Balsa flies better
                • Nov 2014
                • 388
                • Iowa
                That looks fantastic Doc!!
                Jeff
                • boomer108
                  Chief Boom
                  • Apr 2014
                  • 867
                  • Chicago IL.
                  That plane is gorgeous Doc!
                  Roy B.
                  • doctormike
                    • Oct 2013
                    • 1260
                    • Santa Fe NM
                    I thank all of you. Doc
                    • Flygirl
                      • 969
                      • Glen Burnie, Maryland USA
                      Look at you posting pics!! Wooohooo!!! Looks great Doc! I love the scheme...! I have seen that real world plane in a picture somewhere but I can't remember where... Oh wait... I know... There was one just like it in Flight Sim 2004 that someone painted and I always flew in the sim.
                      Lauren
                      • doctormike
                        • Oct 2013
                        • 1260
                        • Santa Fe NM
                        Thanks, FlyGirl! There must be hundreds of Tiger Moths still flying, and every paint scheme different. I made my living as an artist/ sculptor for 45 years. I'm finally using my experience on something I REALLY like! Doc
                        • rc-eflyer
                          • 210
                          Oooooh.......she's a real looker Doc. I had a 2 meter Bird of Time (us older gents will even know what that is) with that scheme and always got great comments on it. She'll look even better up in the air!
                          Steve
                          AMA 95495
                          Freewing P-51D Iron Ass
                          Freewing F-86 80MM
                          • doctormike
                            • Oct 2013
                            • 1260
                            • Santa Fe NM
                            I built a Thermic 72 freeflight glider when I was 16. I've always liked that polyhedral gull wing. Doc
