Actually this is me when my A10 hit the sign
How well do you crash?
John Wick movie clips: http://j.mp/1QKkh6S BUY THE MOVIE: http://j.mp/1SGyAvJ Don't miss the HOTTEST NEW TRAILERS: http://bit.ly/1u2y6pr CLIP DESCRIPTION: Jo... -
Baja 1000... I am not worthy!!! WOW thats Awesome.Current Hanger: FW, F4.F22,F14, Byron T-6, Top Flite P-47, Top Flite P-40, Top RC P-51 H9 P-51, SebArt Avanti, Yellow aircraft Spitfire, T Jeti Extreme Flight EDGE, DS-24 Carbon,Comment
I know you're addressing Rifleman but I thought I'd chime in. I have never used hot-melt glue on my RC planes, its not a good solution in my opinion. It is very heavy, dries very quickly, and doesn't adhere nearly as well as other glues - but I know that it is extremely popular (for example with Flite-Test planes) because its cheap and fast. I'd love to see some other opinions. Foam-Tac is much better for foam and doesn't add a lot of weight (since the solvent evaporates).
With these foam planes, even major damage like the one in Rifleman's picture is pretty easy to fix as long as you have all the pieces. Many of the breaks are clean (usually) so the pieces will fit back together well. Start with the small pieces first and start putting each piece back together, one at a time. Check for hidden cracks and make sure they are glued as well. As you get to the larger pieces, be careful to check alignment. When you're done, cracks and parts that are crushed can be fixed with filler (sometimes more than one coat) which is then sanded down to a smooth finish. After repainting these planes can look almost like new again.
For me the hardest thing is when the foam is compressed. Those wrinkles are hard to fix and sometimes the foam is bent soo much to the point where its really hard to get is looking right.... but usually that's when I just get a replacement part.Marc flies FW & FL: AL37, MiG-29, T45,F4, A4, A10, F104 70 and 90, P38, Dauntless SBD, Corsair, B17, B24, B26 & P61, Lipp.P19, ME262, Komets, Vampire, SeaVixen, FMS Tigercat, FOX Glider & Radian XL.
Rabid Models foamies, including my 8' B17 & 9' B36... and my Mud Ducks! www.rabidmodels.comComment
I second that and add that Gorilla(white 1hr stuff) works great for filling voids and securing firewalls that have shaken loose. Use it instead of Foam-Tac whenever you need a solid non-flexible joint.;)Warbird Charlie
I would like to mention that they have some Gorilla branded products, which are not different from any other company's adhesive products (like regular clear CA for example).
In other words, understand there is a distinction between their unique polyurethane products, and their other Gorilla-brand adhesives like CA and epoxy.Marc flies FW & FL: AL37, MiG-29, T45,F4, A4, A10, F104 70 and 90, P38, Dauntless SBD, Corsair, B17, B24, B26 & P61, Lipp.P19, ME262, Komets, Vampire, SeaVixen, FMS Tigercat, FOX Glider & Radian XL.
Right On ;)
In other words, understand there is a distinction between their unique polyurethane products, and their other Gorilla-brand adhesives like CA and epoxy.Warbird Charlie
A good crash sets a record.
Such as when I left pieces in 8 trees over 100 yards.
Or the time the plane took a straight dive between 2 trees and got caught between the trunks with only cosmetic damage.FF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
I would say epic crash is when you hit a road sign and bend the sign post over 8" with a foam plane on impact also loosen up the retainer bolts on the sign, and a bang loud enough to sound like a negligent discharge.Comment
Then there was the high speed low pass with the Dynam Me262, bounced it off a fire hydrant at appx 100 mph... continued flying. Nose gear needed work.FF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
