How well do you crash?
  • #81
    Originally posted by fhhuber View Post
    Then there was the high speed low pass with the Dynam Me262, bounced it off a fire hydrant at appx 100 mph... continued flying. Nose gear needed work.
    And the pilot needed to change his pants...
    • #82
      Then there was the first fun fly at my current club.
      I could barely handle figure 8 laps around the field at that time... but they talked me into trying.
      Almost hit the CD (with the airplane) twice.
      Broke the back of the airplane 3 times. (glued it back together with CA and 5 min epoxy... off we go... CRUNCH!)
      • #83
        Remember to disconnect the motor battery from the ESC immediately . If you forget to disconnect, you may have an unplanned startup in the pits when you attempt to take off another model ( If you don't have Spektrum "model match")
        • #84
          Disconnecting the motor battery after a crash is a smart move but it won't do anything to how the TX was last left after a crash. You still have to make sure that the throttle is lowered and for double safety, hit the throttle cut.
          • #85
            Model match is so nice to have ..
            • #86
              Was flying a 90mm EDF straight and level downwind leg at 2/3 throttle with landing gear deployed. aircraft rolled 180° on its back and proceeded to nose in to the ground. Checked all servos after crash they seem to be functioning , battery was ejected on impact so I could not verify if there was a signal interruption. Any ideas on what could have caused this scenario? Thanks, Ken
              • #87
                Hi Ken, were flaps deployed? I have had flaps deployment where only one deploys causing a roll moment...Luckily I was able to save it. That could cause a roll like that. If a servo gets stuck it could cause a roll...Of course loss of signal or momentary brown out could cause that as well...Unfortunately without some kind of advanced telemetry it may be impossible to know with 100% certainty. Sorry to hear about the crash!
