Help!?!?! Foam Hinge Repair!!
  • Loneflier
    • Aug 2013
    • 603
    • Huntsville, AL
    RE: Help!?!?! Foam Hinge Repair!!
    Originally posted by Hippie 64
    I got some of the hinge tape but haven't tried using yet . Anybody else ever tried it ?
    I have used it, and it does seem to work well, but I prefer the Welder's now that I have found that method. I did find out that you can use Welder's right over the hinge tape too!
      • 7415
      A little late, but Watch this, he also does a hinge repair/substitute good video
      • retiredflyer
        • Aug 2014
        • 333
        • Sanford, Maine
        If you look on You Tube, there is a demo at a trade show for Foam-Tac that the guy makes a perfect hinge joint. Strong and flexible. Just runs a bead of Foam-Tac along both pieces.
        Addicted to planes!
        • farmflyer
          • Mar 2015
          • 1164
          • Quitaque Texas
          I ordered some foam tac from MotionRC last week just for repairs such as this. I've got several foamies with a lot of time on them mostly with foam hinges and they're starting to show their age. Thinning and cracks on lots of the hinges. I'm planning to try foam tac on them.
            Another excellent foam hinge repair glue is ZAP GOO. Also works on mounting plastics to foam like canopies.
            For the hinge it is flexible and stronger than the original foam hinge crease.
            • doctormike
              HobbySquawk Moderator
              • Oct 2013
              • 1260
              • Santa Fe NM
              Any of the rubber contact cements will work well. Welders, which you have to order online or E6000 from Walmart. Pin hinges, however, are the best permanent solution. Have fun! Doc
