Originally posted by JDill
View Post
MCB-E ("blue box") Issues, Post up your experiences
This is an update to the MCB-E (Blue Box). The MCB-E always had a sequencer built into it with a built in delay for the gear doors. This is not ideal since some planes don't need the delay for gear doors. It depends if the plane has spring operated gear doors or servo operated gear doors. The delay is only needed for servo operated gear doors. The micro switch turn the delay on/off depending on servo operated vs spring operated gear doors. Note, there have been quite a few other updates over the years. This is the latest.
Aaaahhhh, that makes sense now. I noticed in some Bronco videos that there was a delay in gear actuation and expected it with mine, but there wasn't one. Thank you, thank you, for solving this mystery for us 😀Originally posted by Tom View Post
! IMPORTANT
It took me 1 hour to understand why the takeoff LEDs weren't lighting up with my Spektrum ESC. Spektrum ESCs only deliver 6 volts or 7.2 volts and Freewing Control Box MCB-E only accepts 5 volts to light the takeoff LEDs.
I just did the test with an ESC that delivers 5 volts and it works !
Take the test, you’ll see !
Otherwise tell me your solution,
regards 😉​
Having a retract failure.Triple checked connections and even tried a second receiver and a servo tester.
No luck at all.
Would this be a 'blue box failure'?​
Tried two receivers, two transmitters.
Only way I can run the gear is to bypass the blue box.
Can anyone help?
Thanks in advance, John.​
So the retracts only work when you bypass the blue box.Originally posted by Johnboy384 View PostHaving a retract failure.Triple checked connections and even tried a second receiver and a servo tester.
No luck at all.
Can anyone help?
Seems like it's giving you a pretty good hint that the blue box is the problem.
Is there any reason you can't just leave it bypassed?
Thanks Kallend,Originally posted by kallend View Post
From a search of blue box issues they seem various and ongoing. Will delete the box and replace it with Y-leads.
My first and last blue box experience.
J
