What's next from Motion RC?
  • Bob Symes
    Warbird Tragic
    • 43
    • Orange NSW Australia
    Originally posted by Wesnc
    +1
    Make that +2
    • Gilatrout
      RC Pilot Addict
      • 806
      • Albuquerque NM
      Will those new paint schemes mentioned in the .eu announcements be available in the .us store? I likey
      • James
        Administrator
        • Aug 2017
        • 1543
        Definitely! Sorry if that didn't come across.
          Here's something new!
            Definitely digging that Mirage!
            • AkumaZeto
              Achtung Stormtrooper
              • 907
              What does the clipped wings offer? Less washout?
              AMA 1102566
              • Gilatrout
                RC Pilot Addict
                • 806
                • Albuquerque NM
                Originally posted by Craig Dieter
                Check out the build thread for Pat’s Connie. You can get to it from Pat’s web site. A Connie your size you need to add rudders.
                Pat flies at our field and we get the pleasure of seeing his prototypes tested. The Connie is a beautiful plane and his model is spectacular.
                  The clipped wings increase roll rate, impart a more "crisp" feel during non-scale snappy maneuvers, slightly increase top speed, slightly reduce washout, and make the bird even easier to transport. Seen here in the backseat of a Honda Fit:
                  We designed the Spitfire from the start to be modifiable and future-compatible with 3DP upgrades. This is hopefully just the beginning for scale tweaks and bolt-on updates like pitots and different exhaust stacks and filters and radiators for this Spitfire. I won't call them "Upgrades" as they don't significantly alter the base model per se, but we're doing all this in the spirit of the original Spitfire, which underwent many revisions and alterations throughout its storied service history.
                  Bottom line is, we're doing it because it's fun.
                  And don't worry all, these recent Repaint/Repower/Revise models are separate from New models.
                    It's definitely easier to see!! The Mirage V2's power system puts the aircraft firmly into hover territory. Nose to the moon, near-standstill, hover. We took a fast plane and turned it up even higher based on customer feedback we've collected since the V1 was released ~4 years ago.
ID:	134212Click image for larger version
ID:	134214Click image for larger version
ID:	134209Click image for larger version
                    We'll drop more pictures and info into the actual Mirage's discussion thread, so as not to distract this thread.
                      More choices are always good! Well done:Cool:.
                        I am going to take a PUNT at "Hoot",
                        I believe "Hoot" is a HE-219 UHU (Eagle Owl... hoot, hoot) night fighter, originally I thought this to be tooooo obvious, but then I thought.....when ALL Alpha's clues are NOT obvious, throwing an obvious clue in is counter-intuitive:Silly:
                        Click image for larger version Name:	He-219--g1106a05.jpg Views:	1 Size:	75.1 KB ID:	134161 Click image for larger version Name:	DML_HE219A0_CAT.JPG Views:	2 Size:	154.6 KB ID:	134164
                        I like your style!
                        • themudduck
                          -TMD- Foaming at the Mouth!
                          • 1041
                          • Burton OH (near Cleveland)
                          The UHU was an incredible nightfighter, heavily armed and deadly. and there is only one left (completely restored and waiting for final assembly at the Udvar-Hazy Air & Space Museum near Washington DC). It could be a spectacular model!
                            I like your style!
                            Need to add that one to the "to do" list Alpha. :)
                              Right after the Connnie....?
                              • Gilatrout
                                RC Pilot Addict
                                • 806
                                • Albuquerque NM
                                Originally posted by MotionJB
                                Free plane? uhhh, can I guess? ;)
                                I'm going to guess Wolves refers to VF-84 "Wolf Gang" flying F4U's?
                                • davecee
                                  • 179
                                  • Nashville, NC
                                  One of my problems is seeing these smaller aircraft. A bright color scheme definitely helps. Will the new Mirage scheme be available here in the USA?
                                    Actually, before the Connie.
                                    And let's not forget the Do-335:).
                                    • Gilatrout
                                      RC Pilot Addict
                                      • 806
                                      • Albuquerque NM
                                      There is a wolf rescue sanctuary in Lancaster PA. Hmmm... New .eu store... Lancaster?.... wolves?...
                                      Everyone needs a Lancaster
                                        Click image for larger version  Name:	_DSC9346.JPG Views:	1 Size:	108.6 KB ID:	134212Click image for larger version  Name:	_DSC9350.JPG Views:	1 Size:	116.1 KB ID:	134213
                                        Click image for larger version  Name:	_DSC9313.JPG Views:	1 Size:	196.2 KB ID:	134214Click image for larger version  Name:	_DSC9536.JPG Views:	1 Size:	69.2 KB ID:	134211
                                        Click image for larger version  Name:	_DSC9337.JPG Views:	1 Size:	150.7 KB ID:	134209Click image for larger version  Name:	_MG_4236.JPG Views:	1 Size:	108.4 KB ID:	134210
                                        I have held off on getting one but I can see that is about to change! I really like Deltas... LOL
                                        • tclaridge
                                          Instructor Pilot
                                          • 141
                                          Alpha, tell us about the cockpit and nozzle on the Mirage. Are those 3D models that will be available to print and paint, or are they "bling" to purchase as aircraft add-ons? I persoanally would love to see Motion offer optional "do-dads" like cockpit kits, nozzles, and exhaust for scale upgrades, while it allows you to keep the base price lower for those that enjoy a good "yank and bank" without all the scale gizmos.
