Official Freewing 64mm Lippisch P.15 Thread
  • SanExup
    Originally posted by jasmith41
    previous posts show one with gear and rudder...
    i wouldn't do either, but then again, i probably wouldn't add this one to the hangar either...
    It's better than you think. And easy to hand launch once you use a little up elevator on launch. It's a fun plane to fly! Gear or no gear.
  • MeyerVW
    Originally posted by 1nformatica
    Thanks for the advice, I'll pass on that mod then! I will be using the landing gear as I see you do. Did you block off the "cheeter" holes? My thinking is they may try and suck the plane down to the runway?
    Cheater holes are blocked off.
  • 1nformatica
    Doesn't need one. Saw one fly Sunday and the last thing that bird needs is more control surface...
    Thanks! I shall not bother then, one less thing to worry about!
  • jasmith41
    LOL. I must have been showing off! I do like these fast little planes, they can be a lot of fun.
  • jasmith41
  • 1nformatica
    Originally posted by billyd
    Here's the plugs per your message request. These are improved over the original version (which is no longer accessible).
    Regards
    Bill
    Many thanks Bill! Will print them out today. I'm running with the landing gear so thought they would help prevent the holes sucking the plane down on the runway. Would I be correct?
  • 1nformatica
    Originally posted by MeyerVW
    I did but its not very useful Click image for larger version
ID:	347120 , as in you dont need it. Here is a pic.
  • billyd
    Hi Folks, putting together the P15 and considering adding the rudder but not sure the best way.
    All suggestions, photos, advice welcome!
    TIA
    Regards
    Bill
  • MeyerVW
  • 1nformatica
    TIA
  • jasmith41
    I snuck in a new EFL F16 80mm this week under the premise that I'm giving Buzzy my 70mm one (the white one i've been flying), but she's not buying the story... 🤣🤣🤣 as she pre-pays $8,700 for an airbnb in Scottsdale for the months of October and November for her internship...(essentially for her 'hobby')...
    RC life is just not fair - first I'm out of room and then I'm out of support...
  • themudduck
    You may not recall it, but the day we met for the first time (Bill's field) you were flying this bird - like a mad man, i might add. I think the words I used to describe how you were flying it to my wife were "this guy's got mad skills" - I was blown away...
  • jasmith41
    Hey, remind me to show you how it flies next time we're at the field, I'll show you how it performs. You may change your mind.... maybe!
  • Fighterpilot71
    Hi all, first post. And first plane from MotionRC.
    I learned to fly in the 90's and had a hiatus and im glad to be back. Electric is where I always wanted to be, but it just wasn't quite there yet. Now its nerd heaven :)
    Im a big Luftwaffe fan and this is my first EDF. I got 4 flights on it and this was my experience. From reading through these posts...seems pretty typical.
    Flight one: Hand launched straight into the grass nose first lol. No damage, amazing really. I believe this was all me and when she dipped I probably applied too much elevator and stalled it out.
    Second attempt: Less elevator correction, but she did a belly bounce off the grass and away she went! Holy crap this thing moves and my heart was pounding. It was clear I needed up elevator trim, but it seemed like I needed a lot. So Instead of applying trim I landed it to recheck the CG. My CG was only slightly nose heavy so I increased my Elevator throws to from 70 to 80%. I also mixed in 20% up elevator to full throttle and relaunched.
    Third and Fourth flight were great. Slight dip at launch and she was gone. This plane is a blast at 30-50% throttle and glides forever. It looks so nice gliding by and several people came over to see what I was flying.
    Great job MotionRC!
  • themudduck
    maybe it's just me, but i see no value / entertainment / excitement in this bird... but i know a guy that's got 2 or 3 of them, so may it's me...
  • Jake Bullit
    Not the best video as I only have a hatcam and the P15i s small,but here are a few passes and some DJI FPV flight.
    The extra weight of the Vista affects the performance quite a bit as you miight expect.
    https://www.youtube.com/watch?v=arq8...ature=youtu.be
  • MeyerVW
    Originally posted by oefranz
    Is there a video or some better optional landing gear installation documentation available for the P.15?
    The manual does not really show all the steps, loke taking out the plywood parts to insert the nose gear and the two mail gears. Do I need to cut it out with a Xacto knive, or?
    Any help is appreciated!
    The parts on the aircraft are wood and peel out or off. Then the new gear is glued on, so be careful when removing the wood. covers. I used a small screw driver to pop them out.
  • oefranz
  • jasmith41
  • oefranz
    My P.15 will arrive tomorrow and I am curious if there is still a potential problem with the stock ESC cutting out during flight. If yes, should I switch out the ESC and which would be the best solution? Any advice is greatly appreciated.
