Project Foil Guesses?
This topic is closed.
  • #21
    Originally posted by Prowler901 View Post
    Oh yeah. Flip that "Master Bad" switch :)
    Hey! Maybe "foil" has something to do with gold foil, bonded to a canopy. Extend when you can, turn when you must!:Cool:
    • #22
      they could make a 4 man cockpit for the a6 I would think and call it a growler
      • #23
        Yup, same airframe. Just 59" longer if I remember correctly. :)
        • #24
          Could not say no to a Prowler conversion either!
          But, must admit I think Foil is an F-100, like most seem to.
          • #25
            Whatever it is it will have to be on my wishlist and not my home. Still no i repeat no room lol
            • #26
              was on the rc castle site and saw a freewing g91 90mm jet...it very much like a f100 and it even has a drog chute which I love...ill go with the F100 as foil
              • #27
                What if "Foil" means something like the Hughes XF-11?
                • #28
                  Sorry if I missed something, but where did y'all here Project Foil get mentioned? I can't find any mention of it on Motion's site or here (except for this thread).
                  thanks
                  • #29
                    In this thread:
                    Alpha said it is definitely an EDF, but that's all the info we have.
                    • #30
                      I too am hoping its an F100 but fear that Alphas mind works in more more complex ways!! the connection is way too easy.........
                      • #31
                        Hey, I think the F-117 uses gold foil in some places. Maybe we are getting a twin 80mm F-117? OOOOOOOooooooh yaaaaaa!
                        • #32
                          I think I came up with something! How about the WB-57? So this was in the write up about the development of the aircraft; "The production aircraft were further modified with new TF33-P-11A engines that delivered even greater thrust than those of the prototypes. Foil systems developed in 1962 for the WC-130B to collect particulate debris from nuclear tests were installed in the bomb bay and the fuselage beside the cockpit". Just running down the ideas ALPHA. This could make a pretty good EDF and stable but unique aircraft.
                          • #33
                            Can't remember what thread it was that Alpha talked about the Canberra and the engineering challenges that the wing/nacelle intersect posed for EDF inclusion.
                            It would be the first twin EDF bomber though.
                            • #34
                              I would love a Canberra. They are SO COOL! :Cool:
                              • #35
                                OV10, you could use a plastic spar carryover much like the original. Or simply make a short front spar and a short rear spar insert with the edf pocket?
                                • #36
                                  So here's another one; William Hoot Gibson, Air and Space , An F-100 driver with the Thunderbirds!
                                  • Wall of Honor Location:
                                    Foil: 15 Panel: 4 Column: 4 Line: 37
                                  • #37
                                    You don't need to convince me, it's Alpha that you gotta get to buy in to it. ;)
                                    • #38
                                      I would love to see a 90mm class F-100 Super Sabre............it would be the fastest "add to cart" in history.
                                      • #39
                                        +1
                                        • #40
                                          Yup me too!
                                          AMA 1102566
