Project Foil Guesses?
This topic is closed.
Could not say no to a Prowler conversion either!
But, must admit I think Foil is an F-100, like most seem to.Comment
I think I came up with something! How about the WB-57? So this was in the write up about the development of the aircraft; "The production aircraft were further modified with new TF33-P-11A engines that delivered even greater thrust than those of the prototypes. Foil systems developed in 1962 for the WC-130B to collect particulate debris from nuclear tests were installed in the bomb bay and the fuselage beside the cockpit". Just running down the ideas ALPHA. This could make a pretty good EDF and stable but unique aircraft.Comment
Can't remember what thread it was that Alpha talked about the Canberra and the engineering challenges that the wing/nacelle intersect posed for EDF inclusion.
It would be the first twin EDF bomber though.Warbird Charlie
OV10, you could use a plastic spar carryover much like the original. Or simply make a short front spar and a short rear spar insert with the edf pocket?Comment
So here's another one; William Hoot Gibson, Air and Space , An F-100 driver with the Thunderbirds!- Wall of Honor Location:
Foil: 15 Panel: 4 Column: 4 Line: 37
