Just for the record, the short kit I make comes with the following:
For best results the chute must be compact enough to be firm when wrapped yet loose when installed in the tube. Check out my earlier video where I show how I pack the chute. Paul Helms (Helmsman52) makes beautiful chutes that have been verified to fit perfectly. Others may work but have not been tried by me.
The short kit is not intended to be a simple bolt on solution. It is a custom mod and requires some basic ingenuity and skill to install successfully but it is really not that difficult to do. I have provided enough information for you to be able to make this mod on your own plane but if you have any questions please let me know.
Steve
- Fiberglass tail cone pieces w/strip of FG cloth to glue them together on the inside
- Hinge for the hatch
- Screws to secure the hinge
- Magnets to hold the hatch shut
- A piece of 1/8" lite ply to make a hatch plate. (the chute must push against a flat surface)
- A 2" long piece of Estes BT-55 rocket tube
- The trigger wire and tie-wrap
Steve
