Freewing F-4 drag chute mod
A precautionary note: I lost an F-4 due to what was likely an RF noise induced glitch.
Search this forum on RF chokes or chokes. Read the info presented and consider adding them.
I have not had any radio issues on HIGH CURRENT EDF planes since I began using them.
Your decision….but you may be at risk if you don’t install them.
-GGLeave a comment:
I have tried several things to try to get a smooth finish for the chute mod. I have tried green Tamiya putty, Beacon Foam-Finish and Beacon Hobby Coat, and this last round a very fine spackling compound. For each try I sanded with 2000 grit sandpaper before airbrushing on the paint. I have attached a couple of pics and you will see it is far from getting a smooth finish. Can you please share with me what your technique for doing this is? Thanks!Leave a comment:
What they call performance spackle. It's thicker and dries harder than normal spackle.Leave a comment:
paulsnapp Lightweight spackle that can be found in hardware stores, for spackling walls. It spreads well and sands well, and is light in weight. I know I've seen some you tube videos where a specific brand is recommended. RcGeek probably has a video tutorial. I believe the stuff I have used is made by dap products. There might even be an ultra lightweight. The key word on the label should say sandable.Leave a comment:
I have my chute mod done and ready to go as soon as I repaint the tail section to match. I have finally found a paint mixture to match the original and have sanded and painted twice. Color looks good but I am not happy with the finish around the fiberglass tail mod. The filler seems to stay porous and I can not get a smooth finish. I have tried Tamiya Basic Type Putty and Foam-Tac Foam Filler, sanded and followed with Foam Tac Foam Finish and Hobby Coat. I am using 1000 grit flexible sandpaper. When I sand, the filler does not sand smooth and hard but feels like maybe rubber and stays porous. Could someone please share what you use to fill and smooth gaps and rough areas before painting? Thanks!!Leave a comment:
I’d like to purchase a 24” one
Please message me for payment infoLeave a comment:
The flat diameter is 17” for this certain scale model. The real F-4 chute has a flat diameter of16’. I make chutes according to scale up to 35” in flat diameter. Thanks.
192 divided by your scale = ?
192 divided 7 = 27.43”Leave a comment:
Good job! I prefer to store it "un-cocked" and personally don't use any powder on it but you could use corn starch and it wouldn't hurt a thing.Mod is finished and works great - now on to painting and mounting on plane. I am wondering what the proper storage for the mod is? If it is stored cocked, does keeping the 4 springs compressed reduce their expansion force over time? If it is stored un-cocked, does keeping the trigger wire deflected cause it to develop a bend and not seat in the trigger slot properly over time? Also, is there anything (like corn starch or maybe baby powder) that needed to be used on the chute to allow it to open up more easily after being rolled up? Any feedback will be greatly appreciated!!
Mod is finished and works great - now on to painting and mounting on plane. I am wondering what the proper storage for the mod is? If it is stored cocked, does keeping the 4 springs compressed reduce their expansion force over time? If it is stored un-cocked, does keeping the trigger wire deflected cause it to develop a bend and not seat in the trigger slot properly over time? Also, is there anything (like corn starch or maybe baby powder) that needed to be used on the chute to allow it to open up more easily after being rolled up? Any feedback will be greatly appreciated!!Leave a comment:
Steve - here is a photo before the trigger wire was installed.
1 PhotoLeave a comment:
