I should have it all set up and working prior to Paul getting me his version. I will take pics and vid when done.
Freewing F-4 drag chute mod
OK, chute mod is all done! It works fine on the bench, just need to re-install the tail to the fuse and try it out in the street. I'm currently printing up the 3DPUP nozzles for my F-4, and will install the tail after getting those put on first.
I put bigger magnets in mine as my install was not perfectly straight, and I needed the extra holding power to keep the door from popping open in flight.
One other thing I did was to grind down the tips of the hinge screws so that the chute does not catch on them. I also put a dab of hot glue over each as well for added insurance.3 PhotosPat
- Likes 2
Originally posted by crxmanpat View PostOK, chute mod is all done! It works fine on the bench, just need to re-install the tail to the fuse and try it out in the street. I'm currently printing up the 3DPUP nozzles for my F-4, and will install the tail after getting those put on first.
Nicely done! Still experimenting to gain consistency.Currently flying: Twin 80mm A-10, 80mm F5, 80mm A6, 70mm Yak-130, 70mm F-16v2,90mm Stinger 90, 70mmRC Lander F9F, Flightline F7F TigerCat, Phoenix 46 size Tucano, Flyzone L-39
These really are quite a work of art! It's quite thrilling to see so many modelers taking the F-4 leaps and bounds forward!Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
Originally posted by Alpha.MotionRC View PostThese really are quite a work of art! It's quite thrilling to see so many modelers taking the F-4 leaps and bounds forward!
