  • KevinMar
    They haven't made it clear, though, if the current stock at MRC that is shipping is the reinforced V2 version or not
  • KevinMar
    Originally posted by Gilatrout View Post
    Looks like we might have a V2 of the F15 dropping sometime soon?? Spare parts on the original lists a V2 nose cone in the dark grey paint. It also teases a bit of fuse in a similar darker color.
    Could it be a Strike Eagle?
    Very cool
    Unfortunately not, "V2" is just a version with a reinforced front fuselage
  • Gilatrout
    Freewing 90mm F-15C Nose Cone (V2) [FJ3091105U] Motion RC
    Click image for larger version  Name:	Screenshot 2022-03-21 100930.png Views:	0 Size:	127.9 KB ID:	340532
    Very cool
  • MartinField
    Try mixing out the ailerons when you have flaperons deployed.
  • Cape Jets
    Winter here on Cape Cod keeps me trying new set-ups on my planes. Got a new one for you guys, I think....I want to set up just Taileron/ Evelons on my F-15. I do have a mix now that runs Normal Ailerons-Elevators and one mix that has Tailerons with Ailerons. Can't seem to figure out how to run just Tailerons. Got a 10 Channel Spektrum with a NX 10 so plenty of channels. Any ides would be great. Thx...
    The F-15 is a pig compared to the F-18. They designed the F-18 to fly on a 80mm or 90mm.
    I haven't done it but maybe a strong Jetfan/ HET 6S set up?
  • Big12fan
    Hello everyone, I have been flying this jet on their 8s set-up for years. Mine has probably around 110 flights on it. I tried to buy a bunch of planes and parts from motion last year before they raised their prices to have extra stuff laying around. I’m thinking about going back down from 8s to 6s. One thing that caught my attention was when I bought another F-15 around 2 years again it came with the 12 bladed 1835kv EDF. I pulled that set up and put it in my F-18. That bad rips it up in that plane. So happy with that set up in it. But now I see they come with the 9 bladed 1900kv. I’m wondering if they did this was because to keep weight and cost down. Is the 1900kv just as good as the 1835kv. Anyone familiar with both in their F-15’s? Thanks
  • Cape Jets
    Has any one ordered a Fuse from Motion lately. I know there is V2 out for the plane itself with fuse improvements
    1) Additional carbon reinforcement inside the forward fuselage
    2) Plastic reinforcement along the exterior of the forward fuselage
    3) Modified foam cradle to eliminate cracking stress points during shipping
    4) Enlarged the nose retract to a larger size: SKU# ET8403.
    Would like to get a replacement to replace a tired fuse (encounter with briars, belly landings, run out of runway rashes )
    Before they got the new shipment they still had 3 old versions left. Been waiting till the count goes down before I ordered to make sure I get the V2.
    So just looking to see whats out there for replacements from you guys. Thx....
  • air-jon
    It still seems like there is something missing. Well...i shouldn't care as i have a V1 to finish, but This model certainly deserves a true V2!
  • jasmith41
    Originally posted by Radar-Guy View Post
    I guess that’s what they call the V2 (from MRC EU website)
    As of September 2021, new Freewing F-15s include the following improvements:
    https://www.motionrc.eu/collections/...edf-jet-9b-pnp
    There was also a 3DP file for a “true” F-15 nose cone, I’ve downloaded it a while ago and fitted it to mine.
    They got them back in stock and sent me one, so i'm good - thank you MRC. I also bought a spare just in case.
  • Radar-Guy
    Originally posted by air-jon View Post
    Hw did you get a V2 F-15? I don't see them for sale anywhere?
  • air-jon
    Originally posted by jasmith41 View Post
    Does anyone have a spare nose cone for the v2 version? Mine came without one and Mrc does not have any...
    How did you get a V2 F-15? I don't see them for sale anywhere?
    While we are on the topic, To Motion RC: when will the F-15C V2 go live?
  • jasmith41
  • rms
    I was int in putting a bigger fan in my next airplane..How much space is it up and down from the 90mm fan?
    The one thing I miss in my hangar is a ultra high performace EDF..I look for a plane that is possible to use a 120mm 12s with light batteries. Also considder the FW F22..
  • gooniac33
    Originally posted by shamel7od View Post
    Thanks to everyone for putting up information. Had a great maiden on the f15 yesterday with the 8S FMS setup. I think all I needed was 1-2 clicks of down, Can't wait for the weekend
    Awesome!! This is the set up that I will be using as well...
  • shamel7od
  • gooniac33
    Originally posted by Cape Jets View Post
    Need some guidance on ESC settings for my jets. All my jets have Freewing 130amp or 150amp ESC's. I also use on all my jets the Freewing 90mm 12 Blade 1835kv EDF. (Hughs favorite EDF)
    I just got the Hobbywing ESC Program card to set-up my ESC's. Listening to the beeps drove me crazy and if you miss one step your screwed..... So the question is what do you guys set for your jet esc's ?
    Brake I know is OFF, Lipo Batt , Soft Cut on EDF, Voltage Cut Off-Low, Start mode-Normal, Timing is the big question? Most things I see is all EDF's get set to Low on timing.....
    So I'm throwing it out there to see what you guys set for your jets.... Thx
    set it to low...
  • MartinField
    I noticed when I use telemetry with my Spektrum receiver it’s showing 24.6 Volts with 6 cells at 4.20v / cell. Anyone have any thoughts why the telemetry cable isn’t showing the expected 25.2 volts? It’s not a function of the battery - my Eflite planes all have 25.2 volts with the same battery/telemetry setups.
  • Hench9
    I figured out my problem. So ignore previous posts!
  • Hench9
    The bec lights up when I plug a battery in. And the esc beeps!
