New Avios Mig 17 ?
  • f4u ausie
    Nice mig
  • Icarus the 2nd
    It's been a while since a vid was posted here ..
    Here's a nice flightvid from my good friend Jörg flying his Avios Mig-17 painted into a Syrian Airforce camo scheme.
    The video was shot on August 31, 2024 at the 'Jets over Venlo' meeting in the Netherlands.
  • Husafreak
    Good news, I got my gear sorted. The original set up was pretty elaborate, Rx wired to White distribution box, then to a sequencer board, then to the board that converts the signal to change polarity and lower or raise the gear. I have always had trouble with the gear on this from day one, first I got rid of the inner gear doors, when trouble persisted I got rid of the sequencer board. Then it worked fine for years. So when it started acting up again I assumed a mechanical problem. But when no amount of working on the gear would fix it I took another look at the electronics. I decided to get rid of the White distribution box entirely. A direct connection from the Rx to the polarity change gear driver board has the gear working consistently again. I got rid of the White distribution box entirely, with an admiral 10 ch Rx I had the ports anyway. I've got a dozen flights now no gear issues. Really happy.
    So my Avios Mig 17 has a new lease on life, it has an FMS fan, and just recently an Eagle A3-L gyro, and with the gear working I can just enjoy flying the beast. And we all know how well these Migs fly! I get 4 minutes with my 6200 mAh packs.
  • Vintage Racer
    There are several versions on Thingiverse that might work if he doesn't have one for you
    Thanks I did come up with one. It the Freewing 90MM system which I found without issue.
    VR
  • Gilatrout
    Originally posted by Vintage Racer
    Do you have the file for this attach point? It doesn't seem to be in the download. Thanks.
    VR
  • Husafreak
    The right main gear on mine has become very "troublesome", it has a mind of its own. If anyone has a spare one and wants to sell it (or a set) let me know. Thanks
  • Vintage Racer
    Originally posted by patrick verlinden
    I redesigned the fuel tank attachment for direct fit with the Freewing 90mm EDF weapon attachment. STL file in attachment.Click image for larger version Name:	20190926_191412.jpg Views:	0 Size:	48.7 KB ID:	214593
    VR
  • f4u ausie
    Just bored new paint again to far from kelly .. made my own stars,,, harder than i thought..
  • patrick verlinden
    I designed a scale cockpit set for the Mig-17. If you're interested in the STL printfiles or a pre-printed set, contact me on pat.verlinden@telenet.be
    UPDATE 2021:
    STL-files are still available
    Please note changed email : patv.verlinden@telenet.be
  • patrick verlinden
    Small reminder : The MiG-17 cockpit set is still available! STL files if you can print it yourself, but also complete sets.
    Please contact me at pat.verlinden@telenet.be
    UPDATE 2021:
    - STL-files still available
    - email changed! patv.verlinden@telenet.be
  • f4u ausie
    Yep battery ended up about 10 mm further forward,,, ye the mondo motor is very cool sounds good ,,, goes good.... u can feel the extra weight,, landed a bit faster,,, but fuuun.. was to use hughs term ,, pucker facter.... getin closer to that f4 phantom.. it flew 4 minuts with couple go rounds ended at 3.75 all round thats 4 minuts of throttle time
    As always clevor dick no sillyness,,, meant i was as dumb as dog ****.. sorry . I missed the 300 kv times 10 volts times 20 volts 6000 rpm ... daa thats why u were a fire man and me just a bodyman painter AUTO .. BLA BLA ..... MISSED A ZERO IN THERE... B SAfe think i will b happy with extra speed in that case... yas will soon find out
    I'm retired. That me about as useless as nipples on a bull. You, on the other hand, are important and currently valid. One of our cars is in the body shop right now getting a new fender and paint job. The firemen down the street are having a nap. Guess who I'm in favor of?
  • gooniac33
    Its 1835 kv 12 blade hope 4 a little more speed,,, it already went 4 minuts on a 6000
    You should get all of that! Just a lil heavy in the rear with that mondo motor. Check CG before getting it back in the air! Even with my 9 blade which is really light I had to move my battery forward almost all the way to the front!! Don't fly it tail heavy because it will not end well!
  • f4u ausie
    Actually, that would be an extra 7000 rpm on a fully charged 6s battery.
  • f4u ausie
    Just looked the old one was1550 kv another 1000 odd rpm
  • f4u ausie
    Which kv motor did you get for yours? I swapped mine out for the FW 9 blade inrunner and it was a great fit for the bird! Faster with 4 min flights on a 6000 pack and not all that hard to drop in. i think that a 12 blade would have sounded better but not been as efficient as this one is! It is even more fun now!
  • gooniac33
    O boy ! !,.... no got myself a 90 mm fwing innrunner motor 4 this puppy.. will find its way into a fwing servo plus at some time f22 mayb.... first thought in the mig 17 longer time and more power.. its metal frame.. so need to re cg itchin 4 the weekend
  • f4u ausie
  • starcop
    WTF??!!! I've been in this hobby (helis, quads and planes) for a decade (this time around). I have ZERO interest in trucks, cars, boats, tanks or digging equipment.
    Gosh damnit, it was late. That came out wrong, I was reading several other posts. That's one thing about social texting, things can get missed or not understood. Sorry bro, if I offended you. Matt. I remember you from Customer Service, you were a fire-fighter if I remember correctly? I guess you are very straightforward. That's a good thing.
