Product Page: https://www.motionrc.com/collections...s-90mm-jet-arf
L-39 Albatros 90mm EDF Jet from Black Horse - Balsa Wood ARF - BHL3000
The Aero L-39 Albatros is a high-performance jet trainer developed in Czechoslovakia by Aero Vodochody. It was designed during the 1960s as a replacement for the Aero L-29 Delfín as a principal training aircraft. It was the first trainer aircraft to be equipped with a turbofan powerplant. The type was exported to a wide range of countries as a military trainer.
The model is scaled to approximately 1:7 and attention was paid to a true to original appearance and best flight characteristics. The model can be operated using an electric 90mm EDF setup. Comes covered in Oracover with a sporty and bold blue and white paint scheme. CNC cut balsa and plywood construction for strength and durability.
Visit the Official Black Horse L-39 Albatros 90mm EDF Jet Discussion Thread on HobbySquawk.com for additional photos, videos, reviews, and customer Q&A. FEATURES:
Black Horse ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). PRODUCT SPECIFICATIONS:
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 6+ HOURS
Visit the Official Black Horse L-39 Albatros 90mm EDF Jet Discussion Thread on HobbySquawk.com for additional photos, videos, reviews, and customer Q&A. FEATURES:- ARF model convenience for quick build
- CNC cut balsa and plywood construction
- Oracover covered in an attractive blue and white scheme
- Wing comes in 2 parts to facilitate transportation
- Control surfaces: Ailerons, elevator, rudder, flaps
- Scale suspended oleo struts (electric retracts not included)
- Hand painted pilots and cockpit detail
- Black Horse L-39 Albatros 90mm EDF Jet - ARF
- Scale CNC suspension oleo struts
- 8 Channel radio - select a minimum 8 channel radio from our Radio Collection
- 8 Channel receiver - select a minimum 8 channel receiver from our Receiver Collection
- Brushless Inrunner Motor - (recommendation coming soon)
- 10-12 Blade EDF Unit - (recommendation coming soon)
- 120 Amp Brushless ESC - we recommend ZTW Gecko 120A ESC OPTO High Voltage Brushless ESC
- 8-18 Amp UBEC - we recommend ZTW 18A BEC / UBEC
- 8x high torque servos - we recommend D-645MW (Note: these must be run at a minimum of 6V to generate enough torque.)
- For 8S to 12S setup - we recommend TWO Admiral Pro 4000mAh 5S 18.5V 60C LiPo Battery with EC5 Connector in series for 10S
- 2 to 1 EC5 series adapter - we recommend Admiral EC5 2 to 1 Series Adapter
- Electric retractable gear (73.5 x 44 x 28mm) - (recommendation coming soon)
| Model Scale | 1:7.5 Scale |
| Wingspan | 1450mm / 57in |
| Length | 1860mm /73.2in |
| Weight | 4535g / 10.1lbs |
| CG (Center of Gravity) | Refer to the owner's manual |
| Power System | 10-12 Blade EDF with Inrunner Brushless Motor (required) |
| Electronic Speed Control | 120A |
| Propeller / EDF | 10-12 Blade EDF (required) |
| Servos | Electric - 8 x 45g standard (required) |
| Landing Gear | Electric retractable gear 73.5 x 44 x 28mm (required) |
| Required Battery | TWO 5 Cell 18.5V 4000 mAh LiPo Batteries with EC5 connector in series (required for 10S setup) |
| Required Radio | 8 Channel (required) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | Yes |
| Lights | N/A |
| Hinge Type | Nylon Heavy Duty pin hinges |
| Material | Balsa and plywood |
| Skill Level | Intermediate |
| Build Time | 6+ Hours |
. I would like to see some fiberglass or glass/balsa hybrid models offered by Motion as well.
