Flex Innovations F-100 Thunderbird, 90mm
  • MANFRED
    Any Warbird, any time
    • 299
    • San Diego, Ca
    Ordered this scheme, so glad they went with the 90mm. I purchased the 2 T-33s and although they fly great, they are just a little small for my taste. This is the perfect size for loading in my van. Will need some metal shading and heat tinting on the tail. I wonder if they will come out with an 8s version? A bit pricey, in line with my Eflite SU 30, but should fly great with the Aura. Noticed no gear door on the mains. This one will sell out fast.
  • MANFRED
    • 299
    • San Diego, Ca
    Yeah Baby!!!
    • Beeg
      • 1335
      • Texas
      Pretty cool!
      • MANFRED
        • 299
        • San Diego, Ca
        If it flies great, might have to pick up the Viet thud as well.
        • scootergenie
          Jet lover
          • 261
          • Stuart FL.
          I wonder which factory is producing these ? I like the Vietnam camo.
          • Reaper911
            • 90
            • Winterpeg, Canada
            I hope it comes with T-Bird scheme water slides pre-applied. If not it will be a real bear to put those on.
            • wolpertinger
              Pilot ??
              • 313
              • Earth
              It is a great looking plane at a fairly good price. My only worry is the front nose gear assembly. It is mounted into a thin area of the air inlet so how strong will it be to the occasional "Errant" landing. Was this section reinforced or just a plastic box glued in? Anybody have a read on this before I pull the trigger?
                If all the other flex planes are an indicator, they have wooden supports on their landing gear mounts. Both my RV8 and Cap have them. My sons extra 300 does as well. My buddies flexjet also does, along with his mamba10 and cessna. These guys build their planes rugged. I have no doubt this one will receive the same treatment.
                  Here she flys!
                  • MANFRED
                    • 299
                    • San Diego, Ca
                    Awesome!
                      Has plenty of power even with a full load. I imagine it would have really lit it up unloaded. Probably unlimited vertical
                      • wolpertinger
                        Pilot ??
                        • 313
                        • Earth
                        Thanks for the info Rifelman.... now the decision on scheme.
                          Here she is clean. The flex performance we come to expect.
                          • tab28682
                            RC addict
                            • 338
                            • Fort Worth, TX
                            Highly tempted. Only slight negative is lack of main gear doors. All else looks great, and that can certainly be corrected.
                            If I knew there was an 80mm FW F-100 coming, I would hold off and wait..;)
                            • MANFRED
                              • 299
                              • San Diego, Ca
                              Damn, great flying and incredible landing. Screaming for an afterburner.
                              • air-jon
                                Worlds second slowest builder
                                • Apr 2018
                                • 50
                                • Oceanside
                                Flex did a great job overall on this F-100 model, except those panel lines...which are so big! I would rather have no panel lines than huge panel lines. they can always be drawn on if someone wants them...
                                • Spiritwind
                                  • 10
                                  Hi all, I’m very interested in the F100. I don’t see it on their website. Is it not out yet or I’m I missing it? Thanks
                                    • 2137
                                    • On planet earth....right
                                    https://www.flexinnovations.com/prod...00d-super-pnp/
                                    • Spiritwind
                                      • 10
                                      Thanks T-cat
                                        • 2137
                                        You're welcome .
