I'm using a 6000mah, 6s, HV LiPo weighing 665g - weight is the more important factor than mah as balancing must be considered. Weight differs from one brand to another, even if mah stay the same. It flies the plane with a little more gusto and a little more flight time. I also have the 3-D printed nozzles from Geek. Rafale flies marvelously with this combo.
FMS 80MM Dassault Rafale
If you have (or have access to a 3D printer, my performance enhancing nozzles are here: (They also have improved appearance).
Replacement nozzles for the FMS Rafale, with a reduced exit diameter (52mm, which is 100% FSA), and closer to scale than the stock nozzle. There are two external versions: one has turkeyfeathers open, the other closed. They are both the same internally. Verson 2a has slighly thicker feathers than version 2, needed for some printers. Print with minimal infill for weight savings.
OK, I hate to ask since that would mean someone out there probably had a "doom" flight. I'm in search of the controller box (aka the "magic" box) for the Rafale, pretty sure I got a bum one in my bird. Setup according to the manual with my Spectrum, clean acro, on a wiped receiver. Never got delta mixing on the wings as per the videos, I hit the flap switch and the inboard flaps would go straight up, ailerons down, etc, etc. Just never responded the way I've seen them from a clean setup. The Canard servo linkage popped out on the first cycle (the rod end was less than half way under the set screw) and my battery lead only came about 1/2 inch out from the back of the cockpit. I swear someone on their first shift somewhere in China built this thing. Moved to my Futaba rig and receiver and pretty much the same thing. It was a 9/21 bird. Needless to say FMS's "Great Support" hasn't answered an e-mail and I'm pretty sure my controller is somewhat out of whack. I could move to a 10 channel but jeez those servo wires are a fracking birds nest. So if anyone has an extra "magic box" for the 80mm I'd be interested in buying it just for my own edification!
Originally posted by ITVader View PostOK, I hate to ask since that would mean someone out there probably had a "doom" flight. I'm in search of the controller box (aka the "magic" box) for the Rafale, pretty sure I got a bum one in my bird. Setup according to the manual with my Spectrum, clean acro, on a wiped receiver. Never got delta mixing on the wings as per the videos, I hit the flap switch and the inboard flaps would go straight up, ailerons down, etc, etc. Just never responded the way I've seen them from a clean setup. The Canard servo linkage popped out on the first cycle (the rod end was less than half way under the set screw) and my battery lead only came about 1/2 inch out from the back of the cockpit. I swear someone on their first shift somewhere in China built this thing. Moved to my Futaba rig and receiver and pretty much the same thing. It was a 9/21 bird. Needless to say FMS's "Great Support" hasn't answered an e-mail and I'm pretty sure my controller is somewhat out of whack. I could move to a 10 channel but jeez those servo wires are a fracking birds nest. So if anyone has an extra "magic box" for the 80mm I'd be interested in buying it just for my own edification!
As far as the flaps go, that's what they're supposed to do. When you throw the flap switch, the inner flaps go UP and the outer elevons go down. This is to slow the plane down and help stabilize it during landing. In this configuration, the elevons still function to a lesser extent. I can't comment on your canards. Mine have been solid. As for the short ESC lead, I made a short extension.
Edit: I can't remember exactly as my Rafale is hung up for the winter. RE: those flaps. The inner ones may go DOWN and the outer elevons go UP. In either case, they have to work that way. If only the flaps move then you get either a dive or a sudden climb (it's a delta wing after all). The elevons have to go the opposite way to counter the flaps.
Originally posted by Icarus the 2nd View PostNo take-off issues thanks to the powerful 8S Wemotec setup.
Well this has got my juices flowing.
Mine arrived last week and I really like the looks of it.
I wonder now that its been mentioned, do Geeks nozzles improve the useable thrust performance and I love the afterburners. I am not a speed freak but like scale, stability, and sound. Not into stunts. Just like to see them fly in a well mannered style.
Do Chris's stuff fill the bill. His flap and elevator Guage is great.
Cheers
Bob
Cheers
Bob
Originally posted by NewbieBob View PostViper I have a guy that just printed up some pilots for my RCAF Twin Otter. He could likely do the nozzles too.
which file should I send him? I dont know squat about 3d files. Should it be the feathers open or closed etc.
Cheers
Bob
I think the "open/closed" ones are courtesy of "kallend". Both of his are 100% FSA and I believe his replaces the whole stock nozzles. The ones from the Geek go inside the exhaust opening and are 90%, leaving the stock nozzles in place. They fit perfectly into the rear end of the Rafale. They simply just glue in - no fuss, no muss. I had mine done in bright red. One of my flying buddies got it and printed off a few sets. If you get it from the Geek, it's 8 bucks. I don't mind the looks of the stock outer nozzles.
Originally posted by NewbieBob View PostSo are Geeks nozzles printed at 90% of the size or 100% of the file size. Wondering about the OD of Geeks nozzles inserts at the widest point
Cheers
Bob
Originally posted by xviper View PostWhat kind of battery combo do you use with this? I'm stock and I have to find the smallest 5000, 6s I can to fit in that tight battery compartment and be able to balance it. I think I had to carve out a little foam just to get the battery further back.
Someone has 3D printed off some smaller nozzle for my FMS Rafale .I see a lot if people are fitting these onto the 80mm Rafale .Not sure if I I want to mess with the original nozzles on my FMS Rafale .It fly OK to me with the original nozzle on it .Anyone fitted these 3 D nozzles on to there FMS Rafale and if so what difference does fitting smaller nozzles onto the Rafale achieve ???
Originally posted by Captain Moron View PostSomeone has 3D printed off some smaller nozzle for my FMS Rafale .I see a lot if people are fitting these onto the 80mm Rafale .Not sure if I I want to mess with the original nozzles on my FMS Rafale .It fly OK to me with the original nozzle on it .Anyone fitted these 3 D nozzles on to there FMS Rafale and if so what difference does fitting smaller nozzles onto the Rafale achieve ???
The stock nozzles are 130% FSA
My nozzles are 100% FSA
if that means anything to you, you'll know why people are fitting the smaller nozzles.
(They look a lot better too).
