FMS 80MM Dassault Rafale
  • Airguardian
    Just as promised...
  • Airguardian
    Thanks!
    Next Rafale video is ready, should be able to post it soon :D
  • JA1170squad
    That’s awesome
  • Airguardian
    It was high time for another Raffy vid!
  • kallend
    Originally posted by DCORSAIR
    Hmmmm, nosecone or is that nose cone?........
    Don't give up your day job.
  • DCORSAIR
    Originally posted by kallend
    In case anyone's nosecone got a bit worse for wear, here is a 3DP one.
    Replacement nosecone for the 80mm FMS Rafale. Print light (I used 1 wall and 7% infill).
  • kallend
  • Jake Bullit
    This bird flew great off the beach yesterday.3 mins is never enough:
  • Captain Moron
    Thanks Kallend for that I go ahead and get them fitted then
  • kallend
    Originally posted by Captain Moron
    Sorry I am a dumb arse .That means nothing to me .I assume the smaller nozzle has more thrust ???
    Correct. 130% is WAY WAY too big.
  • Captain Moron
  • kallend
    Someone has 3D printed off some smaller nozzle for my FMS Rafale .I see a lot if people are fitting these onto the 80mm Rafale .Not sure if I I want to mess with the original nozzles on my FMS Rafale .It fly OK to me with the original nozzle on it .Anyone fitted these 3 D nozzles on to there FMS Rafale and if so what difference does fitting smaller nozzles onto the Rafale achieve ???
    The nozzles may be my design. https://www.thingiverse.com/thing:4827133 (there are others out there too).
    The stock nozzles are 130% FSA
    My nozzles are 100% FSA
    if that means anything to you, you'll know why people are fitting the smaller nozzles.
    (They look a lot better too).
  • Captain Moron
    :pray:
  • Icarus the 2nd
    What kind of battery combo do you use with this? I'm stock and I have to find the smallest 5000, 6s I can to fit in that tight battery compartment and be able to balance it. I think I had to carve out a little foam just to get the battery further back.
    Hi, I'm using 2x 4S 4500 25C Roaringtop lipos, no foam carving needed, weight is compatible to a single 6S 5000 lipo. All important info about my upgrade, batteries, afterburner unit, nozzles and exhaust cans, ... you can find at the end of this earlier vid of mine.
  • NewbieBob
    Thanks Viper. Thats exactly what I was looking for.
    Cheers
    Bob
    Originally posted by NewbieBob
    So are Geeks nozzles printed at 90% of the size or 100% of the file size. Wondering about the OD of Geeks nozzles inserts at the widest point
    Cheers
    Bob
    Don't you mean at the "narrowest" point? I believe you print them as per the file and not do any re-sizing of the file. If you look at my picture, you'll notice that where the nozzles attach at the front would be the widest point or the original opening. Now notice how the nozzles taper to become narrower than that, presumably making the final outlet 90% of stock widest point. You should not pay too much attention to those "outer" nozzles. Those are for looks and do not enter into the equation of what the actual exhaust outlet diameter is.
  • NewbieBob
    Cheers
    Bob
  • NewbieBob
    Thanks Viper. I bought Geeks and sent the stl to my friends for printing.
    They look great
    Thanks again
    Bob
    Viper I have a guy that just printed up some pilots for my RCAF Twin Otter. He could likely do the nozzles too.
    which file should I send him? I dont know squat about 3d files. Should it be the feathers open or closed etc.
    Cheers
    Bob
    We used this one: https://www.thercgeek.com/product/FM...rmance-Nozzles
    I think the "open/closed" ones are courtesy of "kallend". Both of his are 100% FSA and I believe his replaces the whole stock nozzles. The ones from the Geek go inside the exhaust opening and are 90%, leaving the stock nozzles in place. They fit perfectly into the rear end of the Rafale. They simply just glue in - no fuss, no muss. I had mine done in bright red. One of my flying buddies got it and printed off a few sets. If you get it from the Geek, it's 8 bucks. I don't mind the looks of the stock outer nozzles.
    Click image for larger version  Name:	IMG_4375.jpg Views:	0 Size:	67.5 KB ID:	363549
