FMS 80MM Dassault Rafale
    • 8814
    I'm using a 6000mah, 6s, HV LiPo weighing 665g - weight is the more important factor than mah as balancing must be considered. Weight differs from one brand to another, even if mah stay the same. It flies the plane with a little more gusto and a little more flight time. I also have the 3-D printed nozzles from Geek. Rafale flies marvelously with this combo.
    • kallend
      • 1877
      If you have (or have access to a 3D printer, my performance enhancing nozzles are here: (They also have improved appearance).
      Replacement nozzles for the FMS Rafale, with a reduced exit diameter (52mm, which is 100% FSA), and closer to scale than the stock nozzle.There are two external versions: one has turkeyfeathers open, the other closed. They are both the same internally.Verson 2a has slighly thicker feathers than version 2, needed for some printers.Print with minimal infill for weight savings.
      • ITVader
        • Mar 2021
        • 5
        OK, I hate to ask since that would mean someone out there probably had a "doom" flight. I'm in search of the controller box (aka the "magic" box) for the Rafale, pretty sure I got a bum one in my bird. Setup according to the manual with my Spectrum, clean acro, on a wiped receiver. Never got delta mixing on the wings as per the videos, I hit the flap switch and the inboard flaps would go straight up, ailerons down, etc, etc. Just never responded the way I've seen them from a clean setup. The Canard servo linkage popped out on the first cycle (the rod end was less than half way under the set screw) and my battery lead only came about 1/2 inch out from the back of the cockpit. I swear someone on their first shift somewhere in China built this thing. Moved to my Futaba rig and receiver and pretty much the same thing. It was a 9/21 bird. Needless to say FMS's "Great Support" hasn't answered an e-mail and I'm pretty sure my controller is somewhat out of whack. I could move to a 10 channel but jeez those servo wires are a fracking birds nest. So if anyone has an extra "magic box" for the 80mm I'd be interested in buying it just for my own edification!
          • 8814
          You might want to clarify what you mean by "magic" box. Neither Horizon nor FMS makes mention of such a piece. They do, however, mention a "main control board" and a "Reflex flight controller", which are both available for purchase. Horizon sells the main control board and have stock. RC Castle will sell you the Reflex as well as FMS directly. Which one are you talking about?
          As far as the flaps go, that's what they're supposed to do. When you throw the flap switch, the inner flaps go UP and the outer elevons go down. This is to slow the plane down and help stabilize it during landing. In this configuration, the elevons still function to a lesser extent. I can't comment on your canards. Mine have been solid. As for the short ESC lead, I made a short extension.
          Edit: I can't remember exactly as my Rafale is hung up for the winter. RE: those flaps. The inner ones may go DOWN and the outer elevons go UP. In either case, they have to work that way. If only the flaps move then you get either a dive or a sudden climb (it's a delta wing after all). The elevons have to go the opposite way to counter the flaps.
            • 5401
            As noted it may be working and you need to (triple check correct ports and wiring first) adjust servo direction and throws in your radio.
            • Icarus the 2nd
              • Aug 2018
              • 164
              • Pajottenland, Belgium
              Cold temps, wet grass, dark skies but the Rafale did well and the afterburner looks great :)
              No take-off issues thanks to the powerful 8S Wemotec setup.
              Enjoy the vid!
                • 8814
                What kind of battery combo do you use with this? I'm stock and I have to find the smallest 5000, 6s I can to fit in that tight battery compartment and be able to balance it. I think I had to carve out a little foam just to get the battery further back.
                • NewbieBob
                  Back at it
                  • Sep 2022
                  • 83
                  • Eastern Ontario
                  Well this has got my juices flowing.
                  Mine arrived last week and I really like the looks of it.
                  I wonder now that its been mentioned, do Geeks nozzles improve the useable thrust performance and I love the afterburners. I am not a speed freak but like scale, stability, and sound. Not into stunts. Just like to see them fly in a well mannered style.
                  Do Chris's stuff fill the bill. His flap and elevator Guage is great.
                  Cheers
                  Bob
                    • 8814
                    Cheers
                    Bob
                    3 of us locals here 3D printed our own nozzles from his file. They make a significant improvement in thrust with them compared to before we put them on. Additionally, another great improvement is using HV LiPo battery. That extra volt is very noticeable. I'd love to try 8s but battery fitment is a concern.
                    • NewbieBob
                      Back at it
                      • Sep 2022
                      • 83
                      • Eastern Ontario
                      Viper I have a guy that just printed up some pilots for my RCAF Twin Otter. He could likely do the nozzles too.
                      which file should I send him? I dont know squat about 3d files. Should it be the feathers open or closed etc.
                      Cheers
                      Bob
                        • 8814
                        Cheers
                        Bob
                        We used this one: https://www.thercgeek.com/product/FM...rmance-Nozzles
                        I think the "open/closed" ones are courtesy of "kallend". Both of his are 100% FSA and I believe his replaces the whole stock nozzles. The ones from the Geek go inside the exhaust opening and are 90%, leaving the stock nozzles in place. They fit perfectly into the rear end of the Rafale. They simply just glue in - no fuss, no muss. I had mine done in bright red. One of my flying buddies got it and printed off a few sets. If you get it from the Geek, it's 8 bucks. I don't mind the looks of the stock outer nozzles.
                        Click image for larger version  Name:	IMG_4375.jpg Views:	0 Size:	67.5 KB ID:	363549
                        • NewbieBob
                          Back at it
                          • Sep 2022
                          • 83
                          • Eastern Ontario
                          Thanks Viper. I bought Geeks and sent the stl to my friends for printing.
                          They look great
                          Thanks again
                          Bob
                          • NewbieBob
                            Back at it
                            • Sep 2022
                            • 83
                            • Eastern Ontario
                            So are Geeks nozzles printed at 90% of the size or 100% of the file size. Wondering about the OD of Geeks nozzles inserts at the widest point
                            Cheers
                            Bob
                              • 8814
                              Cheers
                              Bob
                              Don't you mean at the "narrowest" point? I believe you print them as per the file and not do any re-sizing of the file. If you look at my picture, you'll notice that where the nozzles attach at the front would be the widest point or the original opening. Now notice how the nozzles taper to become narrower than that, presumably making the final outlet 90% of stock widest point. You should not pay too much attention to those "outer" nozzles. Those are for looks and do not enter into the equation of what the actual exhaust outlet diameter is.
                              • NewbieBob
                                Back at it
                                • Sep 2022
                                • 83
                                • Eastern Ontario
                                Thanks Viper. Thats exactly what I was looking for.
                                Cheers
                                Bob
                                • Icarus the 2nd
                                  • Aug 2018
                                  • 164
                                  Hi, I'm using 2x 4S 4500 25C Roaringtop lipos, no foam carving needed, weight is compatible to a single 6S 5000 lipo. All important info about my upgrade, batteries, afterburner unit, nozzles and exhaust cans, ... you can find at the end of this earlier vid of mine.
                                    • 8814
                                    :pray:
                                    • Captain Moron
                                      • Jun 2019
                                      • 213
                                      Someone has 3D printed off some smaller nozzle for my FMS Rafale .I see a lot if people are fitting these onto the 80mm Rafale .Not sure if I I want to mess with the original nozzles on my FMS Rafale .It fly OK to me with the original nozzle on it .Anyone fitted these 3 D nozzles on to there FMS Rafale and if so what difference does fitting smaller nozzles onto the Rafale achieve ???
                                      • kallend
                                        • 1877
                                        The nozzles may be my design. https://www.thingiverse.com/thing:4827133 (there are others out there too).
                                        The stock nozzles are 130% FSA
                                        My nozzles are 100% FSA
                                        if that means anything to you, you'll know why people are fitting the smaller nozzles.
                                        (They look a lot better too).
                                        • Captain Moron
                                          • Jun 2019
                                          • 213
                                          Sorry I am a dumb arse .That means nothing to me .I assume the smaller nozzle has more thrust ???
