Jet designs you would like to see produced
  • #61
    I would swoon over a huge twin Firefox. Probably a pig to fly like the SR-71s Ive seen, BUT that jet is partly responsible for me being in this hobby.
    • #62
      An F9F panther 80mm, kinda' like the T 33 would be nice... sure it would fly great as well..
      • #63
        As I convert and replace the EDF with Gas turbines I would like to see:
        F9 for 90mm EDF
        Mig 15 for 90 mm EDF
        And most off all a SAAB JA37 Viggen for 90mm EDF
        • #64
          It would be great to see a 90mm CT114 Tutor
ID:	306105Click image for larger version
ID:	306106Click image for larger version
          • #65
            +1 on the panther.
            • #66
              Originally posted by scooter genie View Post
              +1 on the panther.
              Make it +2. Or a Cougar.
              • #67
                This would be a radical, not often seen, EDF shape to see zipping by / Twin 80 inrunners. MiG-29 size ... would be awesome.
                Bristol 188. Never quite made it to Mach 2 in flight testing.
                I bet an EDF would fly well. Main retracts would be a tricky engineering feat, however. Might have to put the servos out in the engine pylons and have the gear a bit farther apart than scale, but that would be fine...and more ground stable. That's what "stand-off scale" is all about.
Name:	Bristol 188 below.jpg
                Click image for larger version  Name:	Bristol 188.jpg Views:	0 Size:	138.1 KB ID:	308240
                • #68
                  That would be a big pass for me...
                  • #69
                    Wow! I'm sorry, but that is one ugly looking airplane!
                    Fly low, fly fast, turn left
                    • #70
                      There are RC airplanes I wouldn’t mind flying once (for example, if it were a friends aircraft and I was asked to fly it), yet not own, and then there are RC airplanes I want to fly AND buy/own. They are totally different, ha-ha. I’d fly just about any aircraft, but certainly wouldn’t want to buy/own everything.
                      • #71
                        Ugly, yes. Cool, extremely! I like it!
                        Tom
                        • #72
                          Tom
                          So many of the aircraft have similar profiles and overall shapes. I was looking for something unique....ugly or otherwise.
                          • #73
                            It doesn’t look like they will offer a Grumman Tiger so I’m building one myself...
                            80 mm edf
                            39” span
                            Paul
                            • #74
                              80 mm edf
                              39” span
                              Paul
                              Wow that is excellent! Pay attention Motion RC!!
                              Have you started a build thread anywhere?
                              • #75
                                Build thread here:
                                • #76
                                  Vulcan bomber of the 1960's / 70's in the camo scheme. See pic attached
                                  • #77
                                    80 mm edf
                                    39” span
                                    Paul
                                    Where do you find the foam block stock...? EPO or EPP foam, correct...?
                                    • #78
                                      I'd like to see / come up with / build the QuinnJet from the avengers... that would be too cool... articulating fans in the wings, twin fans out back for fwd thrust... would be large enough so that the wing section was thick enough to hold the total depth of the EDF - 5' long and wide...?
                                      • #79
                                        SU-57 is pretty cool too...
                                        • #80
                                          I do like the A-7. Great attack airplane. F-16 style landing gear.
