Jet designs you would like to see produced
  • BaltimoreBomber
    • Mar 2021
    • 28
    I would swoon over a huge twin Firefox. Probably a pig to fly like the SR-71s Ive seen, BUT that jet is partly responsible for me being in this hobby.
    • didier n
      • Oct 2019
      • 109
      • leopoldsburg Belgium
      An F9F panther 80mm, kinda' like the T 33 would be nice... sure it would fly great as well..
      • Kjell Ake
        • Mar 2021
        • 2
        As I convert and replace the EDF with Gas turbines I would like to see:
        F9 for 90mm EDF
        Mig 15 for 90 mm EDF
        And most off all a SAAB JA37 Viggen for 90mm EDF
        • Daryl
          • Aug 2020
          • 48
          • Calgary, AB
          It would be great to see a 90mm CT114 Tutor
ID:	306105​ Click image for larger version
ID:	306106​ Click image for larger version
          • scooter genie
            • 164
            +1 on the panther.
            • EA-6B Geek
              EW Misfit
              • 485
              • South Central Ohio
              Originally posted by scooter genie
              +1 on the panther.
              Make it +2. Or a Cougar.
              • GliderGuy
                • 1412
                This would be a radical, not often seen, EDF shape to see zipping by / Twin 80 inrunners. MiG-29 size ... would be awesome.
                Bristol 188. Never quite made it to Mach 2 in flight testing.
                I bet an EDF would fly well. Main retracts would be a tricky engineering feat, however. Might have to put the servos out in the engine pylons and have the gear a bit farther apart than scale, but that would be fine...and more ground stable. That's what "stand-off scale" is all about.
Name:	Bristol 188 below.jpg
                Click image for larger version  Name:	Bristol 188.jpg Views:	0 Size:	138.1 KB ID:	308240
                  • 5401
                  That would be a big pass for me...
                  • nuts-n-volts
                    Duke City Electric Flyers
                    • 262
                    • Albuquerque, New Mexico
                    Wow! I'm sorry, but that is one ugly looking airplane!
                    Fly low, fly fast, turn left
                      • 2137
                      • On planet earth....right
                      There are RC airplanes I wouldn’t mind flying once (for example, if it were a friends aircraft and I was asked to fly it), yet not own, and then there are RC airplanes I want to fly AND buy/own. They are totally different, ha-ha. I’d fly just about any aircraft, but certainly wouldn’t want to buy/own everything.
                      • Pogo
                        • 452
                        • Waterford, Ontario, Canada
                        Ugly, yes. Cool, extremely! I like it!
                        Tom
                        • GliderGuy
                          • 1412
                          Tom
                          So many of the aircraft have similar profiles and overall shapes. I was looking for something unique....ugly or otherwise.
                          • Ps2727
                            • Jan 2019
                            • 31
                            • Sherman Tx
                            It doesn’t look like they will offer a Grumman Tiger so I’m building one myself...
                            80 mm edf
                            39” span
                            Paul
                            • EA-6B Geek
                              EW Misfit
                              • 485
                              80 mm edf
                              39” span
                              Paul
                              Wow that is excellent! Pay attention Motion RC!!
                              Have you started a build thread anywhere?
                              • Ps2727
                                • Jan 2019
                                • 31
                                • Sherman Tx
                                Build thread here:
                                • hirth90
                                  • Oct 2019
                                  • 27
                                  Vulcan bomber of the 1960's / 70's in the camo scheme. See pic attached
                                  • jasmith41
                                    EDF-obsessed
                                    • Sep 2021
                                    • 317
                                    • AZ and NE Ohio
                                    80 mm edf
                                    39” span
                                    Paul
                                    Where do you find the foam block stock...? EPO or EPP foam, correct...?
                                    • jasmith41
                                      EDF-obsessed
                                      • Sep 2021
                                      • 317
                                      • AZ and NE Ohio
                                      I'd like to see / come up with / build the QuinnJet from the avengers... that would be too cool... articulating fans in the wings, twin fans out back for fwd thrust... would be large enough so that the wing section was thick enough to hold the total depth of the EDF - 5' long and wide...?
                                      • jasmith41
                                        EDF-obsessed
                                        • Sep 2021
                                        • 317
                                        • AZ and NE Ohio
                                        SU-57 is pretty cool too...
                                        • FoamOvercast17
                                          • May 2021
                                          • 33
                                          • Folsom CA
                                          I do like the A-7. Great attack airplane. F-16 style landing gear.
