I would swoon over a huge twin Firefox. Probably a pig to fly like the SR-71s Ive seen, BUT that jet is partly responsible for me being in this hobby.
Jet designs you would like to see produced
This would be a radical, not often seen, EDF shape to see zipping by / Twin 80 inrunners. MiG-29 size ... would be awesome.
Bristol 188. Never quite made it to Mach 2 in flight testing.
I bet an EDF would fly well. Main retracts would be a tricky engineering feat, however. Might have to put the servos out in the engine pylons and have the gear a bit farther apart than scale, but that would be fine...and more ground stable. That's what "stand-off scale" is all about.
There are RC airplanes I wouldn’t mind flying once (for example, if it were a friends aircraft and I was asked to fly it), yet not own, and then there are RC airplanes I want to fly AND buy/own. They are totally different, ha-ha. I’d fly just about any aircraft, but certainly wouldn’t want to buy/own everything.
I'd like to see / come up with / build the QuinnJet from the avengers... that would be too cool... articulating fans in the wings, twin fans out back for fwd thrust... would be large enough so that the wing section was thick enough to hold the total depth of the EDF - 5' long and wide...?Comment
