  • Radar-Guy
    I think I'm going to investigate whether or not the Mig-29 mains could be used as a replacement for grass ops. May require the removal of some foam (hopefully at the mold marks) but should allow the gear to be fully enclosed in the well with the doors completely closed. I flew my Mig off the grass for the first time last Saturday with no issues, so hoping this will work for the B-2.
    Not just some foam….
    Click image for larger version  Name:	D8976EBE-69C4-4421-9A67-BE0721DB1984.jpeg Views:	0 Size:	65.3 KB ID:	344391
    Click image for larger version  Name:	94AF2EE5-AFEB-4FB6-BF9B-FA35F5DE6EAD.jpeg Views:	0 Size:	59.6 KB ID:	344392
    Originally posted by okcrcpilot
    Take the battery hatch or one of the EDF covers to HD and they will be able to do a perfect match. The paint will be latex and will hold up quite well.
    Roger, that was my next step...
    Originally posted by Colorc
    The servo cover is on the top of the wing. The screws are painted making it blend right it.
    Oh snap! Thanks!
  • okcrcpilot
    Originally posted by Aros
    Hey folks, been gone for a few days, I apologize if I missed the post somewhere but does anyone have the dead nuts paint match numbers for this bird (or DC - Darn Close) I can take to Home Depot or Lowes? She's acquired some slight hangar rash already just from trying to get the clams set right for flight. Much appreciated!
    Why ask that way, do you expect it to snap? DO you have a B-2 that this has happened to?
  • primodus22
    Has anyone snapped the nose gear strut yet?
  • jasmith41
    Nice work Icarus the 2nd , not only did you get off grass in a short distance, it was WET grass, so kudos to Radar-Guy for the mods.
    For those of you interested in B2 historical information, the Smithsonian channel has a series called Air Disasters (great program which sums up my flying skills). This year one of the episodes is called "Stealth Bomber Down", from Season 17 (current), episode #3. It's well worth the view. It details the take-off crash of the Spirit of Kansas from the Guam airbase in 2008 which shut down B2 operations for several months and potentially could have ended the B2 program. There is outstanding real videos, interviews, analysis of the crash to determine the cause and insight into the most sophisticated aircraft in the world, which was quite fascinating to me (especially when you find out what brought it down). Also learned that the $44 Billion B2 program had 21 bombers in total (not sure if that's still current) and initially had 300 hand picked pilots in the group, the best of the best. Each B2 was named after a state, except two which were designated as the "Spirit of America" and the "Spirit of Kitty Hawk". I won't spoil it for anyone interested in watching it, so you'll have to see it for yourself, which IMO is well worth it.
    'great program which sums up my flying skills'... LOL You've never seen me fly before... you got nothing on me...
  • Icarus the 2nd
    thanks!
  • Icarus the 2nd
    Originally posted by viper1gj
    Does anyone have a Home Depot touch up paint code color match for the B-2 paint?
    I made a mix with Tamiya airbrush colors:
    You need Tamiya XF-54 and add a little Tamiya XF-19 at a 20/1 ratio
  • Icarus the 2nd
  • Icarus the 2nd
    Originally posted by Warbirdfan29
    Well done G. !! :-) Kind Regards Jörg
    thanks a lot !
  • Colorc
    Also, does anyone have any idea how to remove the servo arm on the servo for the clam shells? There's no servo cover you can remove there and there's no tool I own that can get into that small area to unscrew the broken arm. Any ideas would be greatly appreciated!
  • kallend
    Originally posted by mshagg
    It's worth reading the A3S3 V2 manual if you want to understand some of the settings in a bit more detail - the E52 manual skips over a lot of it.
    Link: https://www.hobbyeagle.com/manuals/A...al_v2.0_en.pdf
  • viper1gj
    I asked same question a few days ago and no one replied. Please post if you get a color code from HD. Thanks.
  • mshagg
    Hi all
    For those keen to have a play with the gyro config using the programming card, I've posted a google spreadsheet with all of the settings and the B-2 defaults. Also added the settings I'm using as a starting point. You're welcome to add your own settings once you've had a play.
    https://docs.google.com/spreadsheets...it?usp=sharing
    I think it's worth enabling a gyro-off mode, for saftey, and going through the process to set appropriate servo travel limits to ensure the gyro isnt trying to over-drive any of the servos. Other than that, it's largely a personal preference thing.
  • kallend
    Sunday I flew my Mirage, Gripen and F-16... Pretty different.
    I have those LEDs on my Mirage, Gripen and F-16. Also on my Arrows MiG29, my SU-35, my two Hunters, my F/A-18, my two F-104s, my FW Vulcan . . . . .
    The LEDs lights all look much the same as in the video I posted. I also made the controller to turn them on/off using a $4 Arduino. Program available on request.
