    Originally posted by jasmith41
    Thanks - that's what i use to get the off, but those little wheel axle ones are a bugger to get back on when you can't see and shake a lot... :)
    Yeah, putting the little rascals back on is also a problem. What I do is to put a small dab of FoamTac on my finger tip, touch with opposing thumb so both fingers have goo on them. Blot the "C" clip with one finger, pinch with the thumb so that the C clip gets a little glue on both sides. Poke the C clip onto the axle and slide finger away, leaving the C clip on the axle. I then use a small hemostat to squeeze the clip onto the axle. Helps to have a magnet on the hemostat in case the C clip slips. However, when the clip is gooed up with glue, if it slips it kinda just sticks there.
    RC Informer suggests to put a dab of FoamTac on each C clip on a brand new plane so they don't pop off from all the vibration. It's horrible to try to land with one wheel missing.
  • jasmith41
    sorry guys - thoroughly reading isn't my strong-point either...
  • jasmith41
    I wish this would stop. Seems to happen every week. It needs sun for a few days to dry out the field. As you can see from the windmill, no wind, but ..................
    wow - that really sucks, but we had that here last week / weekend...
    it's been 60 here the last couple days and close to 80 tomorrow. def going to go flying early...
  • jasmith41
    Anything hard, pointy and sharp with a magnet on it near the tip will do. I use a glass etching pen but they don't sell them anymore. Here's something that would work:
    https://www.leevalley.com/en-ca/shop...kaAmECEALw_wcB
    Just don't poke yourself.
  • GliderGuy
    On the downside = BUMMER
    On the upside = Opportunity to modify the B-2 to snow skis.
  • GliderGuy
    Hi TwistedGrin….
    The agreement seems to be 8 mm reflex on the elevators and 4 mm reflex on the ailerons.
    I wish this wind would stop!
  • jasmith41
    And good luck getting those E clips off and back on...
    Anyone have any helpful hints from Heloise on that...?
    I'm doing it / have done it, but don't know if there's a better way...
  • TwistedGrin
    Yes on the plastic bag ....saved me many a hard days night.......if you order those clips for spares.....naturally you will have dozens that are incorrect size.
    Large plastic bag is simple to use.....when you can
    Still waiting to maiden my B2 as the winds have been very high for the second week in Fort Worth Texas region
    I have completed the speed break clam shell closed adjustment from 60% Rudder travel (cruise gap at 45mm), set up my 7mm elevator reflex, put in three settings of expo all at the same travel rates, confirmed the Gyro toggles to the three settings (Basic Gain - Attitude Lock - Trainer)......will only fly in Basic Gain. Checked for main gear spring free function movement. Confirmed all control surfaces move correctly both from transmitter and gyro inputs. Glued on the tail peice and slotted the section for the clear dorsal fin for maiden. Fabricated a tail peice protector and mounted to the foam shipping storage transit box. Deployd the non slip for the flight battery.
    Will apply for a loan for funds to fill up the truck with enough gas to get to and from Thunderbirds Field in Benbrook Texas from my hanger: www.fwthunderbirds.org
    TwistedGrin
  • TH95147
    Also do it in a clear ziploc bag so you don't lose the eclip
  • kallend
    Originally posted by Radar-Guy
    I recommend this simple tool, the clipped rear end of an X-Acto blade. A strong magnet nearby might help in catching the clip.
    Click image for larger version Name:	IMG_5309.JPG Views:	0 Size:	97.2 KB ID:	343947
    Great idea - thanks. Price is right too!
  • Radar-Guy
    Originally posted by kallend
    While on the subject of tools, does anyone recommend a tool for removing those tiny E-clips found in trailing link landing gear legs, steerable retract pins, etc?
  • kallend
Name:	Hinge-Pin-With-E-Clips-800_a9a9e0c5-edc8-4f68-88b8-0bc6eca2dc42.jpg?v=1629911813.jpg
ID:	343945 While on the subject of tools, does anyone recommend a tool for removing those tiny E-clips found in trailing link landing gear legs, steerable retract pins, etc?
    Originally posted by Lcacing
    A must have tool for removing/installing ball links. No reason to use needle nose or flat head screwdrivers and risk breaking the ball link or servo arm.
    https://www.motionrc.com/products/be...31475141148785
    Ordering. Thanks!
  • GliderGuy
    Just placed an order! Thanks for the tip!
    Yeah, ball link pliers, amazes me that people don’t have them. Edit. I don’t like those in the link, there are others thinner and straight I like much better. Also has two half round parts to grip piano wire/ gear struts/ push rods and a serrated part. Like these, not condoning use of that site…
    ordered repair parts from Motion for mine yesterday, says Monday may 2nd delivery. Normally 2-3 days, now 12?… Edit, update now says this Saturday!
  • Lcacing
  • GliderGuy
    Deleted post
    So I had the happy circumstance of needing to order parts. I was simply trying to take the starboard pushrods off to twist them to their proper spacing so the clam shells close where they should. Using needle nose pliers I tried popping the pushrod clevis back on to the ball joint. It was not going in to save my life. At some point the entire ball joint arm snapped clean off.
    Then the servo arm snapped off when I was trying to get the other pushrod back on it when it popped off. Why is it so difficult to simply put the clevis back on the ball joints? Somewhere there's a factory worker laughing at me I just know it.
