Official Black Horse Viper Jet 2000mm Turbine Discussion Thread
  • bigd5963
    • Jul 2022
    • 12
    What servo's are you guys using for the elevator and rudder? Do standard servo's fit in the main wing? What lighting system are you using for the wing tips if any and where are you getting it from?
    • cabriol
      • Oct 2022
      • 4
      Hello.
      has anyone finished their jet and done the maiden? I am ready to order this model but I would like to be sure that it is a quality model?
      thanks​
      • cabriol
        • Oct 2022
        • 4
        Hi Spy; ok thank for your feedback. will check these points in details. I have A turbine K85G. I think that it will be ok. I don't like to fly à at the maximum speed.
        • bigd5963
          • Jul 2022
          • 12
          Can anyone that has finished their jet tell me what fuel tank they substituted with since the one that came with the kit did not work?
          • cabriol
            • Oct 2022
            • 4
            I used the original tank from the kit and non problem with it.
            • bigd5963
              • Jul 2022
              • 12
              You are one of the lucky ones! The part that came with my tank did not fit. The rubber plug was to small for the hole in the tank, the metal plate that went at the end of the rubber plug was to big to fit in the hole of the tank and the screw was to small to screw into the metal plate. Nothing worked together. No other plug would work.
              • cabriol
                • Oct 2022
                • 4
                ok; for sure I'm lucky. so maybe you can contact the delaer where you bought your model and request a new tank or new spares from them or Black Horse.
                • bigd5963
                  • Jul 2022
                  • 12
                  Does anybody know what size the fiberglass gas tank is that came with the turbine black horse viper jet?
                  • Gottafly
                    • Mar 2023
                    • 6
                    Would someone mind getting a measurement for me?
                    I’m looking for the max exit nozzle diameter, either at the rear of the fuse/former, or the tail nozzle/cone.
                    I’m almost ready to pull the trigger on it for an EDF conversion.
                    Thanks!
                    Rick
                    • mhinesley@triad.rr.com
                      • Jul 2023
                      Has anyone flown one?
                      • Rhall
                        Doing final balance, with a KT85G4 it balances nose heavy. Have moved batteries back to fuel tank area. Anyone else see similar results?
                        • BJH424
                          • Aug 2020
                          Exactly, I had the same results with the same Engine.
                          • PaulZ
                            Crashing less
                            • 279
                            • DFW Area
                            Hi all! I started my Viper build, Part-1 of the build video is here:
                            Are you all seeing any issues with the landing gear motors? They seem weak and they turn so slowly. Thinking of replacing them with JP Hobby motors.
                            • Rich81
                              Rich81
                              • Jan 2021
                              • 12
                              I've has mine for over 2 yrs, I started with an 80N engine and later upgraded to a 102N when I added a smoke system.
                              • PaulZ
                                Crashing less
                                • 279
                                • DFW Area
                                https://youtu.be/K2HSX0oZgpw?si=pFbz-zVYe20iBBZE
                                Thanks for the video. I am also starting with a SW80 sionce I have the engine. Might upgrade later...
