What servo's are you guys using for the elevator and rudder? Do standard servo's fit in the main wing? What lighting system are you using for the wing tips if any and where are you getting it from?
Official Black Horse Viper Jet 2000mm Turbine Discussion Thread
You are one of the lucky ones! The part that came with my tank did not fit. The rubber plug was to small for the hole in the tank, the metal plate that went at the end of the rubber plug was to big to fit in the hole of the tank and the screw was to small to screw into the metal plate. Nothing worked together. No other plug would work.Originally posted by cabriol View PostI used the original tank from the kit and non problem with it.
