Official Freewing 90mm Eurofighter Typhoon EDF Jet Thread
  • kallend
    Originally posted by drexrc
    I have a Frsky X20s, and yes, the travel of the channel goes from -100 to 100, I’ve also tried doing it from 0 to 100, it works perfect once, but then I return the switch to its original position (which made the thrust work forward at first) and i still get reverse thrust no matter go many time I toggle the switch it’s stuck in reverse. If I unplug and plug the battery it works fine.
    1. Try plugging a servo into the reverse channel RX port, and see if it moves through its entire range when you toggle the reversing switch.
    2. Try plugging the ESC's reversing lead into a servo tester, and see if you can get the ESC to work properly that way.
    Doing that should tell you if the problem lies in your radio (TX/RX) or in the ESC.
  • kallend
    Originally posted by Nyuhasz
    Per the original post:
    “My TX is Futaba T6K and RX aid Futaba R3008SB. The lead isn’t plugged into anything lol.​“
    His Reversing lead isn’t plugged in
    That was NOT the post replied to. The reply was to drexrc. You quoted EazyStreet27.
    Sorry, I don’t have any other ideas. Hopefully someone else does, good luck.
  • drexrc
  • Nyuhasz
    Originally posted by kallend
    Evan is most likely correct.
    You don't say what your radio is, but if it has a monitor screen, check to see that when you switch the reversing switch that the reversing channel output goes all the way in each direction.
  • kallend
    I have an issue with the reverse throttle. Once I use it the motor will not come back to normal, it will just operate as reverse. Until I unplug and plug the battery it goes back to normal. Anyone have this issue?
  • kallend
    I fly Futaba for all my jets (turbines and EDF)!and I always reverse the throttle channel in the TX. Try that.
    That doesn't reverse the motor. It just reverses the direction of the stick response.
    Not me. Verify that the channel you have the reverse lead in is travelling the full -100/ +100. Not 0 to-100 or 0 to+100.
  • drexrc
    If the ESC is arming and he's getting thrust it's not his throttle channel being reversed. But that is a common issue that people with Futaba run into.
  • Nyuhasz
    I think you just answered your own question. To reverse any AC motor going through an ESC you can swap any two of the three leads between the ESC and motor. If you have a reversing ESC like in this you can connect the lead for reversing and reverse it using a spare channel.
  • EazyStreet27
    What is the thrust reverse lead plugged into on your receiver? And what TX/RX are you using?
    (If all else fails, swap any two of the three leads from the ESC to the motor - but that should be a last resort).
    just wanted to add that everything else works perfectly.
  • kallend
    Originally posted by EazyStreet27
    Hello everyone,
    I’m having a little trouble with my 6S version at the moment and maybe someone can help me out. For some reason mine is stuck in thrust reverse and I have no clue how to get it to get it out of this lol. Any help would be appreciated!
  • EazyStreet27
    Hello everyone,
  • BenOzzy94
    Awesome, thanks dude.
  • kallend
    For those interested in messing with the gear/door sequencing or the lights, here is the mapping of the ribbon cable:
    - (black)
    + (red)
    elevon signal
    retract signal
    landing light
    position (wingtip) light​
  • TGoelzer
    Maiden in the books. Weather here in the Carolina's has been cold and windy. However Yesterday afternoon we had a window between 6pm and dark were the wind subsided (still a bit cold).
    I have the 8S Version
    Plane flew amazing! Without Ordinance I had not 1 trim adjustment. Was locked In! I went with the recommended throws and the high rates worked well. I did install the weight that came with the plane and mounted it in as far back as possible. Still nose heavy but not too bad. Waiting on the Afterburner kit before adding any more weights.
    2nd flight with ordinance: Needed several clicks of down elevator to keep it from climbing. Flew with the nose up slightly but tracked well.
    Airbrake doesn't seem to affect any pitch up or down at half throttle.
    Sound of the New 8S motor is awesome. Was able to get 4 min flights out of my 2 SMC 5300mah 75c 4S batteries. I run both the High Voltage and the Standard Lipo. Both came down at 4 mins just below storage charge (3.78 to 3.79 per cell)
    Overall very Impressed with it. Lands on the mains and the nose up easily.
  • BenOzzy94
    For the sequencer remember that the mains door close after the gear extend but the nose stays open… between that and the mains retracts being through the ribbon cable I decided to just live with it.
    I've decided (as I don't fly off grass) to leave the main doors open when the gear is deployed like the full scale does.
