Freewing/Hobbywing Skywalker V2 reversing ESC - programming
  • rjhuyck
    • Oct 2023
    • 7
    Thank you.
    • Olivier_
      • Sep 2023
      • 36
      • France
      Originally posted by kallend
      The new FW reversing ESC (which appears to be the same as the Hobbywing Skywalker V2) is in several new and updated EDFs from Freewing.
      If trying to program it with the programming card, the current one listed on MRC's site doesn't work. No new programming card is listed yet.
      If programming the ESC using the transmitter method and using a Spektrum transmitter, be aware that the default Spektrum pulse length at full throttle (1.9ms) may not be long enough to trigger entry to programming mode. On a Hobbywing I couldn't even enter programming mode when increasing the Spektrum's throttle channel "travel" to its maximum. I had to use a servo tester with pulse length 2.2ms before I could get the ESC into programming mode.
      If anyone knows of a programming card that works with the new ESCs, perhaps they would let us know.
      How do you connect the servo tester on the ESC ?
      Could you send a photo please ?
      • Olivier_
        • Sep 2023
        • 36
        • France
        It's good, I managed to wire the ESC to a servo tester and enter programming mode !
        Fortunately I came across your solution because MotionRc told me that the ESC was defective !
        thanks !
        now I have to find a solution to calibrate from the radio because it is a twin-engine plane with 2 ESCs​
        • Sotm
          Old Flyer
          • Oct 2015
          • 5
          Update: I contacted Hobbywing and the response was that the correct card for the Skywalker V2 (and presumably the Freewing reversible) is:
          Although the Skywalker is not listed on that product page.
          This will NOT/does NOT work with the Freewing 100AMP reversing ESC!!! Won't even show selections on display!!
          • kallend
            • 1877
            MotionRC no longer even lists Freewing ESCs except as replacement parts.
            Shop RC airplane and helicopter ESCs at Motion RC. Find brushless electronic speed controllers from 6A–200A with SBEC/OPTO options for reliable motor control.
            I wonder what's up with that?
            • kallend
              • 1877
              Oh yes it does.
              Works fine with the 80A Freewing reversing ESC. I bought one from Motion just 2 weeks ago and programmed it tonight using the Hobbywing card.
              It is VERY fussy about the order in which you plug things in. If you don't get it right it doesn't work. Follow the Hobbywing instructions exactly.
              EDIT: Just tried it with the Freewing 100A reversing ESC in my Avanti. Worked fine there too. Image shows reverse brake enabled.
              Click image for larger version  Name:	IMG_0059.jpg Views:	0 Size:	85.3 KB ID:	409838
              Clearly you or your informant connected one up incorrectly.
