Based on the famous close air support A-10 Thunderbolt II, also known as the "Warthog" or "Tank Killer" this is the updated version of the Freewing twin 64mm A-10. Featuring a European theatre camouflage, full-house functionality including flaps and retracts, and updated power systems, this is sure to be a stunner. Typical to Freewing quality, this plane looks amazing and flies rock-steady and fast. The twin 12-blade EDFs produce an amazingly realistic jet engine sound, while giving it plenty of power for high speed maneuvers, and the wing planform allows stable flight at slow speeds.
Full Functionality Including Flaps The Freewing 64mm A-10 V2 now includes fully functioning flaps for additional scale detail while helping promote slower landings and takeoffs. |
European Theatre Camouflage Livery Adding to the uniqueness and scale appeal, the A-10 comes with a decisive military green European Theatre camouflage. |
Twin 12 Blade 64mm EDFs The twin 12-blade EDFs produce an amazingly realistic jet engine sound, while giving it plenty of power for high speed maneuvers. |
Ordnance Included To further along the scale appeal, a full set of ordnance is included right out of the box. |
Electronic Retracts With Simulated Scale Struts The electronic retracts include wire struts that are covered with plastic detailing to simulate a closer-to-scale look and feel. |
Updated Pilot for Improved Scale Appearance A truer-to-scale sized pilot was added to the V2 A-10 to complete an impressive overall scale profile both for static display and in the air. |
- NEW! European theatre camouflage livery
- NEW! Full functioning flaps are pre-installed for quick take-offs and slow, scale landings
- NEW! Utilizes 2840-2850Kv Brushless Outrunner Motors
- NEW! Utilizes 40A ESC’s with reverse thrust
- NEW! New pilot figure that is more correctly sized to scale
- NEW! EDF units are now screwed in place
- NEW! Wing is now better secured with additional screws
- Officially licensed by Northrop Grumman
- Ultra-scale design including US Air Force graphics, hand-painted pilot, detailed cockpit, machine guns, bombs and drop tanks
- Twin 12-blade 64mm Electric Ducted Fans (EDFs) provide great power and realistic sound
- Nylon hinges on all control surfaces
- Freewing A-10 Thunderbolt II V2 Twin 64mm High Performance EDF Jet - PNP
- Motors, ESCs, retracts, flaps and servos all pre-installed
- Owner's manual
- 6-7 Channel radio (7 for thrust reversing) - select a minimum 6 channel radio from our Radio Collection
- 6-7 Channel receiver - (7 for thrust reversing) - select a minimum 6 channel receiver from our Receiver Collection
- 4 Cell 14.8V 3300 - 4000mAh LiPo Battery with XT60 Connector - we recommend the Admiral 3600mAh 4S 14.8V 40C LiPo Battery with XT60 Connector
- 4 Cell compatible battery charger - select a minimum 4 cell (4S) charger from our Charger Collection
AGE LEVEL :14 and up
SKILL LEVEL :Intermediate
BUILD TIME :1-2 Hours
| Wingspan | 1100mm / 43.3in |
| Length | 1000mm / 39.4in |
| Flying Weight | 1390g / 49oz |
| CG | 45-50mm aft of the leading edge of the wing at the root |
| Power System | 2x 2840-2850Kv Brushless Outrunner Motors |
| Speed Control | 2x 40A Brushless ESCs with Thrust Reversing |
| Propeller / EDF | Twin 12-blade 64mm EDFs |
| Servos |
| Landing Gear | Retracts with plastic, over molded wire struts |
| Required Battery | 4S 14.8V 3300-4000mAh LiPo with XT-60 Connector |
| Required Radio | 6-7 Channel radio (7 channels for reverse thrust) |
| Rudder | Yes |
| Flaps | Yes |
| Ailerons | Yes |
| Lights | No |
| Hinge Type | Nylon hinges on all control surfaces |
| Material | EPO Foam |
| Skill Level | Intermediate |
| Build Time | 1-2 Hours |
| Recommended Environment | Outdoor |
