Official Freewing 90mm PLAAF J-10A EDF Jet Thread
    • 8228
    PLAAF J-10A with 12-Blade Ultra Performance 8S 90mm EDF Jet from Freewing - PNP - FJ32121P
    Version Note: This is the 8S version which comes with a 90mm 12-Blade EDF 8S Power System with a 4075-1350Kv inrunner brushless motor and a thrust reversing 120A ESC.
    The J-10A is a medium-weight, single-engine multirole aircraft designed for air-to-air combat and other various strike missions. Produced by the Chengdu Aircraft Corporation (CAC), the J-10 is used in the People’s Liberation Army Air Force (PLAAF) and became operational in 2006. Utilizing its delta-wing aerodynamic configuration with canards and fly-by-wire system, the J-10A is capable of turning in a much tighter radius than conventional aircraft.
    The Freewing J-10A 90mm EDF Jet is a highly detailed, scale version of the real J-10A, and features the J-10 “Red Hawk” livery. One of the most detailed releases from Freewing, the J-10A features 11 daylight bright LED lights, including one to illuminate the Heads Up Display (HUD), many scale detail parts, as well as a quick-release ordnance package. Additionally, the Freewing J-10A utilizes screwless, quick-release wings making transport to and from your flying site a breeze.
    Visit the Official Freewing 90mm PLAAF J-10A Discussion Thread on HobbySquawk.com for additional photos, videos, reviews, and customer Q&A.
    Super Scale Details Throughout
    The Freewing J-10A is incredibly well appointed for an EPO model with several attention-to-detail scale pieces.
    Screwless, Quick-Release Wings
    The Freewing J-10A comes with screwless, quick-release wings for fast and easy access for transport or storage.
    Illuminated HUD Panel
    A hint of a new era in the super scale EPO foam class, the J-10A includes an illuminated HUD panel.
    Ordnance Included
    The quick-release ordnance comes included right out of the box to finish off that super scale appeal.
    Functioning Canards
    This J-10A comes with fully-functional canards enhancing the scale detail emulating the full scale version.
    Spring-Loaded Top Cheaters
    Incorporating an innovative ammenity, Freewing has added spring-loaded top-side cheaters that only open and close based on air pressure differential.
    Retracts with CNC-Machined Shock-Absorbing Struts
    Another primary scale appeal and feature of any detailed 90mm EDF jet, the J-10A comes with electric retracts including CNC-machined shock-absorbing struts.
    11 Daylight-Bright LED Lights
    The 11 Daylight-Bright LED lights complete the package of scale detail and appeal in dawn, daylight and dusk hours.
    • Screwless, quick release wings for fast and easy transport and storage
    • Illuminated Heads Up Display (HUD) adds a new level of super scale detail
    • 12 Blade factory-balanced 90mm EDF with 3668-1960Kv (6S) or 4075-1350Kv (8S) Inrunner Motor
    • 120A ESC with Thrust Reversing to help decrease landing roll out
    • Electronic, retractable landing gear with CNC-machined aluminum, shock absorbing struts
    • Spring-Loaded Top Cheaters
    • 11 Daylight bright LED lights
    • Scale details include antennas, pitot tube, cockpit detail, lighting and ordnance
    • Conveniently designed quick detach ordnance included right out of the box
    • Nylon hinges on all control surfaces
    • Removable, magnetic nose cone for convenient transport and replacement
    • Freewing PLAAF J-10A Ultra Performance 8S 90mm EDF Jet - PNP
    • 12-Blade EDF power system (installed)
    • 4075-1350Kv inrunner brushless motor (installed)
    • 120A ESC with thrust reversing and EC5 connector (installed)
    • Electronic retractable landing gear (installed)
    • Servos, LED Lights (installed)
    AGE LEVEL :18 and up
    SKILL LEVEL :Advanced
    BUILD TIME :3-4 Hours
    Model Scale 1/10
    Wingspan 940mm / 37.0in
    Length 1530mm /60.2in
    Empty Weight 3235g / 7lbs 2oz (w/o battery)
    CG (Center of Gravity) 163mm (6.4") from the leading edge of the wing at the root
    Power System 8S 4075-1350Kv Inrunner Brushless Motor
    Electronic Speed Control 120A thrust reversing, EC5 Connector
    Propeller / EDF 90mm 12-Blade EDF
    Servos
    Landing Gear Electronic retractable main gear and steerable nose gear with all metal shock absorbing struts
    Required Battery 6 Cell 22.2V 5000 mAh LiPo and 2 Cell 7.4V 5000 mAh LiPo batteries with EC5 connector in series
    - OR -
    Two 4 Cell 14.8V 5000 mAh LiPo batteries with EC5 connector
    Required Radio 5 Channel (6 for thrust reverse) (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Canard Yes
    Flaps No
    Lights Yes
    Hinge Type Nylon Reinforced
    Material EPO Foam
    Skill Level Intermediate/Advanced
    Build Time 2 Hours
    Recommended Environment Outdoor, 150+ foot paved runway or short manicured grass
    • 8228
    8S (USA):
    Buy Freewing PLAAF J-10A Ultra Performance 8S 90mm EDF Jet - PNP online at Motion RC. Order online with fast delivery.
    6S (USA):
    Buy Freewing PLAAF J-10A High Performance 90mm EDF Jet - PNP online at Motion RC. Order online with fast delivery.
    ARF PLUS (USA):
    • T- Elbert
      • Sep 2020
      • 98
      • Helena, Montana
      Ooh… goody goody
      • Gilatrout
        RC Pilot Addict
        • 806
        • Albuquerque NM
        Meh
        not the model. Looks like the attention to detail is excellent and it looks good, but the subject just isn’t that interesting to me.
        it sort of feels like a PRC directive to make something Chinese
        If it had been a Chinese MiG 15, 17, or 19 something with history and character I’d be all over it. But this subject. Not so much
        • Flanker271
          Spool up that fan!
          • 81
          • Gilbert, AZ
          Meh
          At least it's not another F-16, A-10, or a P-51.
          Freewing is a Chinese company and there is a huge domestic market. Funny you didn't say the same thing about any "American directive" every time when Freewing introduces a US jet.
          J-10 was a big deal in China at the time of debut.
            • 8228
            Personally it's not for me but I have no problem with diversity. US models are ubiquitous so I enjoy any foreign model just for the sake of diversity. There are some nice scale features here that hint to what's to come for future Freewing models. I look forward to them.
            • T- Elbert
              • Sep 2020
              • 98
              • Helena, Montana
              I like the deltas and already have graphics on order. Going to paint it up as a Israeli Lavi
              • slamdance64
                • 70
                • Ottawa, Ontario, Canada
                I got the 8S version and everything works, but for some reason the ESC will not arm. I will have to open it up and see what is happening. It does look amazing and I can't wait to fly mine.
                • wldecker
                  "This aggression will not stand!"
                  • Jun 2018
                  • 22
                  • Tucson, Arizona
                  Looks cool, I just won't buy a Chinese plane that probably used other countries tech to design this plane. Not in my hanger. Looking forward to the next 1600mm warbird!
                  • shortround91
                    • Nov 2023
                    • 301
                    • Princess Anne, Maryland
                    Well I love my J10 very neutral flying a alpha monster great landing gear, I did refinish mine to help me see her otherwise no complaints from me at all would buy another if something happens to this one
                    • Icarus the 2nd
                      • Aug 2018
                      • 164
                      • Pajottenland, Belgium
                      Well here's what I think is the first vid showing the 8S J-10 operating from a grass runway.
                      The 8S setup is a real beast, the plane just wants to launch itself and fly
                      It's a vid with the best parts of 2 flights, the lighting conditions weren't good at all and I had to cut away a lot of unfocused parts. But it has 2 take offs and landing, roll, loop, split S, low pass, ...
                      I'm really happy with the plane, this one will give me no problem on my short 80 metres only and bumpy grass runway.​
                      • Tridente
                        • Jun 2024
                        • 4
                        Hi everybody
                        No chance to put in one single 8S 5000mAh Lipo pack?
                        Regards
                        Chris
                          • 5401
                          If you give me dimensions (and weight) I can check.
                          • Tridente
                            • Jun 2024
                            • 4
                            nice, coming back to you tomorrow. Already late here in Europe.
                            • Tridente
                              • Jun 2024
                              • 4
                              dimensions for 8S5800mah are:
                              160*70*45mm OR 6.3*2.75*1.8 inches
                              thanks for measuring..
                              Chris
                                • 5401
                                The problem is the 70mm width. the tip of the canard servo arms are about72mm apart. On mine the strap is right there too. My 6+2 is 66mm wide and too close to the servo arms for me so I stack the 2 atop the 6, mostly because of the strap. If you reposition the strap and are super careful it may be okay. You might be able to place the battery on its side but may have to trim some foam under the canopy. Mine are only 40mm tall and 130mm long. Also balance may be an issue. Mine are 800g for the two and all the way back and balance just right.
                                • Tridente
                                  • Jun 2024
                                  • 4
                                  Thanks for your analysis, looks like it is a solvable issue. Question is not if I will get one, only when...:)
                                  I think an X45 is the right thing to put in.
                                  Christof
                                  • Jon @ Two Bros RC
                                    • Feb 2024
                                    • 16
                                    Here's our channel's take on it.
                                    Includes a setup guide at the end if you want yours to fly similar to ours.
                                    • Nino
                                      • 10
                                      I have the 6S version. The ESC is cutting in and out during take-off off and some various throttle setting
                                      • Nino
                                        • 10
                                        I have the 6S version. The ESC is cutting in and out during take-off and some various throttle setting
