FW F86
    • 2818
    • Arlington, TX
    I agree with OV10, best to get used to the Mustang first and feel out how much space you need for landings. The thing that concerns me is a 200 ft grass takeoff. I didn't fly mine on grass much, but when I did it took a long time to get airborne ~400ft ish with half flaps. Granted, mine wasn't the best cut or smoothest grass, but its still cause for concern..100 ft takeoffs is no problem on pavement or geotex though.
    • gooniac33
      The Original Gooniac
      • Jun 2016
      • 1047
      Originally posted by bluewaterjoe
      Chopper and gooniac33.. Thanks for the great input and sharing your perspectives!
      The price on the 64mm is definitely easy on the wallet and certainly is an option to consider. Chopper, it does sound like you and I are in similar spots and its helpful to hear your experiences on the progression. I'll have to watch some YouTube videos on that size and thanks for the tip on the underhand launch (never tried that). I'm guessing jumping to jets in either the 64mm or 80mm will be a fun rush. However, I gotta say after watching some of the videos on the 80mm I'm drawn to the substantial size and the awesome sound it produces.
      All you guys have commented on the size of the runway and that's probably my biggest concern at this point. Our field is grass and just doesn't feel that big compared to most of the videos I've seen. I'm thinkng take offs would be fine but the landings may be a different story! I'd probably have to hit the very beginning of the field right after the tall grass ends. I guessed our field is about 200 feet but I may have to do a bit of measuring. I'm kinda judging how far it is from Home to first base on a baseball diamond and thinking it's about twice that distance. maybe...
      I'm in a suburb of Chicago so our weather is still a bit chilly (although this weekend is supposed to hit the upper 50's) so I have a few weeks before pulling the trigger on this. I'm also sitting on a new FMS P51-D V8 Marie that
      I need to get together.
      Anyway... I'm thinking this jet thing is gonna be a blast!! Then there's that red Yak-130 that looks so cool :) ...
      Thanks again Guys!
      Joe
      The Yak is a great plane too! It is a little smaller and faster than the F-86 but they handle the same. The F-86 is a really sweet flying plane though. it is perfect for a first bigger EDF. It is forgiving in the air and just enough of a challenge on the ground to get you ready for the others in the series.
      • AkumaZeto
        Achtung Stormtrooper
        • 907
        I would wait. You need to be more than profeciant with high powered warbirds. When I started this thread last year I was ready to make the jump but I would not advise this if you have not flown larger high powered low wing birds. It does need one hell of a roll out on landing too
        AMA 1102566
        • bluewaterjoe
          • Jun 2016
          • 18
          Great wealth of information from you guys and, again, it's much appreciated!
          I think it makes perfect sense to get the Marie in the air and get comfortable with it, especially with the field size. After all, that's why I bought her and look forward to flying it as well :). The 80mm Sabre is still in my sights and It's great to know it's
          within close reach. Man, I have to figure out how to carve out more flying time. This work stuff gets in the way :).
          I may also pilfer a receiver from another plane and for $89 bucks get the 64mm Sabre as a stepping stone to get my jet fix while flying the Marie.
          I watched some videos of the 64mm and I can see Chopper's point as how it can belly land in a short distance.
          I like that there are multiple levels to this hobby as it never gets dull.
          You guys have given me a lot of great options to consider. Thanks Again!
          Joe
          • AZFlyer
            EDF and Scale Warbird Pilot
            • 194
            • Arizona
            I love my F-86. It's the best EDF to fly in windy conditions, I think. I've flown it fine with 10mph wind 90 degree across the runway, and it handles fine.
            I don't think it's that fast, but it sounds great. It sounds a lot better than any other EDF I own, including the T-45. The way the fuse is tuned for the 80mm fan is great. Sounds like a jet screaming by, especially in a hard bank turn away from the pilot.
            I fly an Admiral 5000. I removed the ESC bracket and push the battery all the way back against the fuse. Didn't have to carve out anything (I don't think). I get 4 minutes out of it, no problem.
            Definitely recommended as the first big EDF for someone new at these.
            Enjoy!
            • gooniac33
              • Jun 2016
              • 1047
              The F-86 is a great entry into the bigger edfs. It is actually the size of a 90mm jet if you think about it. The F-5 is a fraction of the size but still uses the same power system and has much higher performance as a result. The only issue with the F-86 and cross winds is the taxi. It tips pretty easily.
              Now another thing to think about here... the Mig-21 is a great plane too! Wider stance and really wide speed range. The wings are stubby but the airfoil is really thick! I would say that it is a good one to start with too....
              • Alpha10
                J e t - J u n k i e
                • 377
                • Chicago
                Definitely... The MIG21 is a great flier if you can get past it's horrible looks haha!
                The F86 should've been a 90mm for sure, but it does pretty well on good 80 considering it's size!
                • gooniac33
                  • Jun 2016
                  • 1047
                  It is hideous... until you fly it and see what amazing things it can do!! here it is performing on a short runway...
                  • Alpha10
                    J e t - J u n k i e
                    • 377
                    • Chicago
                    That's a great flying plane man... I just can't get past the looks haha! It's gotta have the look to boot for me.
                      • 2818
                      • Arlington, TX
                      They just need the same system in an F-106, then the looks problem is solved :).
                        • 7383
                        Hey BWjoe! Your in Chicago, maybe you'd consider going to Nefi in Muncie in the middle of June, a bunch of us, including Charlie and me, will be there and you can check out a big variety of birds there and actually see them fly. The best way to judge whether it fits your needs and environment. The runway factor had got to be taken in to consideration.
                        • bluewaterjoe
                          • Jun 2016
                          • 18
                          Hi Grossman! I had to google what Nefi is :). Saw a bunch of pics on Flickr and it looks like a good time with a lot of cool planes. I may have to get down there if work and time permits.
                          Thanks for the invite!
                          • bluewaterjoe
                            • Jun 2016
                            • 18
                            Hey that MIG-21 doen't look that bad LOL... What the heck is that spear on the front! I like it!
                            Do you guys find that it's easier to lose orientation with the jets? I'm watching some you tube videos where the jet is pretty far away and the guy is doing some fast barrel rolls. Seems
                            like it would be hard to come out of the rolls knowing if you're right side up or upside down??
                            • Lon
                              • Jul 2014
                              • 1202
                              • Miles, Iowa
                              Decided to upgrade my F-86 to the inrunner and 100amp ESC....DANG! The ESC/Motor wires are a few inches short!! And my soldering skills/experience is terrible to make up some extensions. I see MotionRC sells the extensions in 16awg, but the upgrade ESC is 12awg. Thinking that's not a good idea to buy/install 16awg.
                              Lon
                                It's for roasting marshmellows...
                                  Where is your ESC located? The F-86 comes with motor wire extensions already on it or at least mine did. I just swapped mine to the Mig-21 1800 kV fan and went with the Gecko 125A ESC. It's overkill I know but what I had. I had more motor lead wires than I knew what to do with.
                                  • Lon
                                    • Jul 2014
                                    • 1202
                                    • Miles, Iowa
                                    The leads are just short enough that I can't position the ESC Perpendicular to the fuselage in the designated position. Need about an inch more of lead to get it turned into position.
                                    Lon
                                    • Lon
                                      • Jul 2014
                                      • 1202
                                      • Miles, Iowa
                                      Issue resolved...made some extension leads 12awg.
                                      Lon
                                        • 7383
                                        Anyone not sure about Nefi, check out the video links that I posted here, scroll down the page
                                        Well, it's only 4 1/2 months to NEFI, so all you guys who missed out on it last year, start planning! There are campsites just to the rear of the flying field if we
                                        • AirHead
                                          • 313
                                          • TorCan
                                          She will do her first voyage in the Spring. Practicing flying lots of jets on the sim during the winter nights. Crashing as often as kharma dictates. I have upgraded to the 1850Kv Inrunner package with a Gecko 125A esc. I made up this paint scheme from an internet simulated repaint. I know the foam will likely bubble in the sun, but she's ready to rock. Last Fall, I put her in my arms, put her at full throttle and cleared all the leaves from the back patio. Wow. I chose the dark scheme because far away, all planes become dark anyway. She's the Blue Meanie!...
