BAC Lightning F6 64MM
  • Dayzemass
    • Dec 2018
    • 19
    Originally posted by Wrongun
    Looks fantastic and a different idea with the two seat conversion. I moved the lead from under the lower exhaust ring, I thought I would need more because of the move forward but a reshuffle in the battery compartment seems to have resolved it.
    Can't push my 2200 4S battery further back, but is balancing OK with the leader I've added, plus with the FPV gear in the area behind the canopy has moved the CG forward.
    I'm prepping 2 x 3D printed Firestreaks my friend created on his Bambu printer.
    He's used light PLA , just a few grams, hoping it's not going to upset the CG again.
    Really looking forward to this one both FPV and LOS. The bright scale scheme should help a little with LOS...So the theory goes lol.
    • Dayzemass
      • Dec 2018
      • 19
      Auto correct spelt leader, I mean lead. Should proof read before I post! 😆
      • kallend
        • 1877
        Be aware that if using my missile designs there are now two options for the Firestreak and RedTop. One is permanently glued in place, the other has tabs for insertion in a socket (also included) so the missiles are easily removable/interchangeable.
        https://www.thingiverse.com/thing:7203817
        • Dayzemass
          • Dec 2018
          • 19
          I used firestreaks on mine, many thanks!
          I've swapped the motor and ESC in mine, 3100kv/ 50 amp Admiral ESC.
          I also managed to fit a 4S 21700 Li-ion Eve 40PL pack into the battery bay. The power from the fan is incredible!
          Wasn't going to use Li-ions due to them making the model nose heavy, but since the motor upgrade, balances out great, so I've built a 4S pack. (4000 mah )
          The T5 is RTF now, only need to install a 5v BEC as I'm running 6 servos.
          I'm hoping the thing will be almost ballistic in flight, yes it's heavier , but given there's so much thrust I don't envisage any problems.
          FPV system is spot on and working, the view from the left seat is epic.
          Hopefully fly soon.
          • kallend
            • 1877
            Admittedly my eyes are > 80 years old, but I find this Lightning with the upgraded fan unit gets really small very fast. I clocked just over 100mph with the missiles off, and just under with the Firestreaks on.
            Don't take your eyes off it.
            • Dayzemass
              • Dec 2018
              • 19
              I did get it flying, 4 x flights now and using fixed gear, did 1 LOS flight and it's fast but seemed lacking, then made 3 x FPV flights and hadn't noticed in my OSD the throttle setting doesn't exceed 97...
              Did some research and it would appear my TX16S can't calibrate my throttle via the onboard flight controller above 97. So increased the end points and seems to have fixed it, so next time, will be full power, I guess in comparison to lighting the burners 😆. It was however moving at a quick rate on the reduced power settings so am hoping she's going to really move now.
              I bought a second Lightning but just modifying the canopy for strictly LOS flying.
              I did test fly first , and being lighter , she really moves, the vertical is very impressive, and yes had to concentrate hard keeping it in sight, but it's a great flyer, need just a little more aileron expo, but otherwise very happy with it.
              Here's a few photos from the FPV sorties and my new model canopy mods .
              Am using 4S EVE 30PL Li-ion cells for this. After a 4 minute flight, 72% remains in the pack, amazing cells, extremely low IR. ( One of my 5 packs pictured ) They're good for 60 amps constant discharge too.
              My FPV model weighs 175 grams over the stock version detected no nasty flying habits all all.
