Originally posted by FLYRCJETS
View Post
Freewing 90mm F-16 - Thoughts anyone?
I believe you mean nose heavy if it's landing hot... That forward of a cg would cause that.
Great, glad your liking the F-16, great flyer too, been flying the F-16 for three yrs now, I find the sweet spot on CG around 118mm, I put the new FW 4068-1835kv in mine, it is better than my 4068-1680kv on flight times, performance wise just little more thrust.
7 flights on the TB version and I'm finding I like the 115 CG so far. Been pretty fun little bird! First landing was kinda fast as I was tail heavy a bit.
I've been doing some research on motors. scorpion was up on the top shelf with a few others. gotta start somewhere wright.
hi to all, i have a f16 falcon , and i would like to switch out the stock 90mm edf. need a little more punch. any ideas? i was thinking about putting a scorpion motor in it.
Yeah it's nose heavy as I stated that in my post. Just a couple of clicks of up trim is needed from the neutral point and it lands so much better with nose weight, for me that is, my CG is not for everyone, if you like a neutral CG then do not try mine......:)Originally posted by Alpha10 View Post
IDK man, that looks like a REALLY nose heavy cg to me...
You must have an extreme amount of up trim in your elevator position to fly that far forward.
I ended up between 123-126mm... Much further aft.
IDK man, that looks like a REALLY nose heavy cg to me...Originally posted by DCORSAIR View PostIt's real easy to balance, where the wing meets the fuselage at the very leading edge tip, just measure back from there, I have over 100 flights on mine and it has a large CG range, but here is the problem with that. If you go with the stock CG from the manual anywhere in that range you will find that the F-16 will rotate nicely, the problem with the CG back to far is, it likes to float and pitch up on landing, with the CG forward, it doesn't rotate as nicely, kind of jumps off the runway and it will drop the nose more in the turns but flies great nose heavy, not as pitchy and lands so much better, cut your power on final to low throttle and the nose will pitch up, hold a little up elevator at a nose high alpha and use your throttle to adjust your sink rate and she will glide right in to a nice flare. It will take you a few landings to get it right but once you get it you will love the F-16. Here is a picture where I fly mine, comes out about 110mm-112mm, just put your fingers over the wing spar hole where my pencil is pointing, I balance mine upright and gear down, fly it this way until you get used to landing it, if you fly it tail heavy as per the manual, you will find it hard to land. Your fingers will make a small indent in the foam, makes it so easy, set it on the ground reach under it and feel the holes and waalaaa, adjust your battery to your liking on each flight.
From the wing root, where the wing meets the fuselage and gear down. Balanced up side down, although as its a mid wing this is not critical.
Freewing 90mm F16 CG
The manual is not very clear but is the balance point measured from the tip of the wing? I want to make sure before i fly that i have it correct. Upside down or not for balancing?
I flew my F-16 for the first time in what must be nearly a year! What a great plane. I've got the inrunner version and yes it is a little heavy but I like it like that. To me it feels fast enough. It's a bit more tricky to land than f-15 but still if you have a decent length runway it shouldn't be an issue. If not get brakes! Problem sorted!
Other than a possible short somewhere the only other thing that came to mind is that you might have had a brown out. That is when the voltage level drops too far to supply enough power for all of the servos. Brown outs typically happen during the operation of the landing gear and flaps. The best way to avoid them is by installing an inexpensive voltage protector that is basically a capacitor that plugs into your receiver.Originally posted by Rocketdog58 View PostI am new here and just have a question . I just got the 90mm Freewing F 16 and after 3 flights when I use my landing gear it causes all my control surfaces to go crazy and of course it resulted in a bad crash . Any idea what might be happening here ? I got the plane from Motion RC and have contacted them and waiting for a reply from them .
exactly!! It flies great when you set it up right which make take a couple flights. I went through and totally checked over my F-15 and realized that there were some issues with how I had set it up. Once I fixed that it picked up quite a bit of speed with my modded set up. I am sure that with a stock set up it would have suffered pretty badly. Flaps are flat now, ailerons are flat and so is the tail. No extra drag and it flies great. The F-16 will be the same for sure. I will be getting one soon as well...Originally posted by DCORSAIR View PostYour going to love it, just fly it stock as it comes out of the box, you don't have to change a thing, you don't need tailerons or flaps, you just need to set it up correctly and put some flights on it, once you learn to control the power on final, it's a baby to land.
