Official Freewing 90mm EDF Stinger 90 Thread
    • 2693
    Originally posted by swordsn
    I got everything working,just need a good weather day.It's a little nose heavy with the 6000 Admiral battery.
    I use the same, or a Roaring Top 6250, both the same weight and I'm also a little nose heavy, even with the battery all the way back. The repaint added some weight aft and I also have an afterburner in that added weight aft, but I still put 3/4 ounce of lead in the tail to balance.
    • swordsn
      • Feb 2020
      • 10
      • Williamston South Carolina
      I tried to fly mine with the 6000 Admiral battery and the nose would not come up after about a 200 foot roll out. Did every one balance up-right or inverted.I plan to re-balance inverted after moving the battery as far back as possible.
        • 2137
        • On planet earth....right
        Once you installed the 6000mah 6S LiPo, did you check the balance of the aircraft to ensure you achieved the recommended CG/CG-range?
        Were you flying off a grass runway?
          • 2693
          I'm flying off of grass and use either the Admiral 6000 or the Roaring Top 6250, both about the same weight although the RT is 24g lighter. I had to put the battery as far back as possible plus added 3/4 ounce of lead in the tail. In addition to that, the repaint and urethane added weight to the back and I have an afterburner installed as well, all adding tail weight. Even so, still needed the lead. It takes off of the grass with take-off flaps in less than 100 feet with the stock outrunner, so I'm surprised you are having a problem. T-CAT is no doubt correct, you must still have it too nose heavy. On asphalt, it takes off in 50 feet.
          • swordsn
            • Feb 2020
            • 10
            I was on asphalt. I did check the balance up-right and it is nose heavy with the 6000 battery as far back as possible. The sequencer and light box stop the battery from going back any more. I might need to move everything back and re-balance inverted. I don't have a lot experience with fan jets, my experience is with giant scale gas warbirds.This is a used jet and I wonder if the motor is sub-par.
            • swordsn
              • Feb 2020
              • 10
              When I re-balance I will probably need to add tail weight as you did.
                • 2693
                The most recent EDF Motion has in the Stinger 90 (for at least the last couple years) is the 12 blade 3748-1650 Kv outrunner. If you remove the fan you should see the markings. Assuming that is the same, the motor should be fine in that jet. Good luck.
                • swordsn
                  • Feb 2020
                  • 10
                  I checked the balance inverted and it was right on at 110mm and slightly nose heavy at 120mm. and this time with a 8mph head wind it lifted right off. I did use about 200 feet of runway. It flew great.
                  Thanks for all your help guys.
                    • 2693
                    Got 20 flights in today on 4 EDF's, with 5 on the Stinger 90. I'm now flying it with the RT 6250 35C battery and am getting 5 minutes of aggressive flight time. I think I'm finally getting to the point where I can fly it with a lot of high end maneuvers with 0 pucker factor. It only took about 60 flights to there though. This was my 1st EDF and man, it's come a long way since that first flight. Haven't had to do any "repairs" for quite a while now. 2 point high alpha landings have finally become the norm. I think it flies better than the Avanti and just as easy, but it wasn't always so. Can't believe how bad I was when I first got it! And I love the sound of the 12 blade EDF (and the 12 blade inrunner in my F-16). One of the turbine guys at the field said they both sounded almost like a turbine. On the other hand, the 9 blade stock outrunner in the F-4 sounds like in comparison, way to whiny. But damn, the F-4 does fly nice, so I just put my headphones on and listen to a little Country while I'm flying the F-4!
ID:	259268Click image for larger version
ID:	259269Click image for larger version
ID:	259270Click image for larger version
                    • Shauncat
                      • Jul 2020
                      • 17
                      Hi Gentlemen, 6 Cell 5000mah batteries are difficult to find in my hometown Durban South Africa. Can I fly the freewing 90mm jet with 6 Cell 4000mah or with 2 x 4 cell 5000mah battery packs in series?
                      Regards,
                      Shauncat drummer boy.
                        • 5392
                        Yes to the 4000. Two 4S give you 8S so no.
                        • awat70
                          • Aug 2017
                          • 9
                          Did you remove the red pain from the stinger or paint over it with the yellow and black?.
                            • 2693
                            I assume you are directing that question to me. First I removed the decals that would come off easily with tape which were the decals on the underside (decals on the red painted surface did not come off easily so painted over those). Then I put 2 coats of Varathane Spar Urethane water based clear gloss as a "primer". Then spray painted both sides with Rustoleum 2 in 1 white primer, followed by Rustoleum 2 in 1 gloss Golden Sunset. Final paint was with testors black enamel, hand painted. I sent Callie Graphics the designs I wanted for the Stinger logos, Hornet on the tail, 2 different scorpions, etc. and she printed them better than the designs I sent her. Final touch was 3 coats of the Exterior clear Gloss urethane.
                            Actually did 2 of them (only difference was the underside and top of the elevators), both with afterburners. Definitely one of Motion's best flying sport EDF's along with the Avanti, 5 minutes on a RT 6250. This is a great frame to customize to your liking and IMO really needs it!
ID:	283882Click image for larger version
ID:	283883Click image for larger version
                            • awat70
                              • Aug 2017
                              • 9
                              Yes Hugh, it was for you and thank for telling how you did it.
                                • 2693
                                Just a quick tip for you (took me a while to learn it myself) if you want to respond to someone or ask a specific question in this forum of someone, either hit the "quote" button on the bottom right or type out their member name, such as yours with an @ sign before it. Looks like this: awat70.
                                Then that member will get a notice that either they were quoted or mentioned in a post. Welcome to the squawk , don't be afraid to post something or feel like you're asking a silly question, then at least I won't be the only one saying something stupid. This forum is chocked full of super smart and great dudes that will be able to answer any question out there.
                                • awat70
                                  • Aug 2017
                                  • 9
                                  Thanks Hugh Glad to be here.
                                  • Shauncat
                                    • Jul 2020
                                    • 17
                                    Hi guys, I'm fairly new to Edf jets, I currently have the Freewing T33, the venom v2 and I've just purchased the freewing stinger 90 jet. I was thinking of flying the stinger 90 first. I've seenots of reviews and videos on utube and the stinger 90 looks to be the easiest one to fly. Any advise on setup, rates expo and flap settings, would be greatly appreciated. God bless you all and your families 🙏👏
                                      • 2693
                                      The Stinger 90 and the Avanti are 2 of the easiest EDF's to fly, IMO. I think you will love it. Since you're new to EDF's, just keep in mind that these fly (especially the Stinger) much faster than what you may be used to. But keep in mind this jet flies very well at 50% throttle, so take it easy the first few times out. The Stinger was my first EDF and the first time out I was at 80% or more throttle most of the time and it was very hard for me to even see the orientation (which is one reason I did a complete re-paint to the yellow and black seen above) and I was attempting to land way to too fast, fearing a wing stall. Well it actually slows down nicely for landing at about 25% throttle or less, then 2-3 feet above the ground you can reduce it even further to nothing and let it float it, but keep the nose up and land on the mains. It has plenty of thrust so climbing/taking off and anything you want to do including knife edge it will do.
                                      Regarding setup, I use a RT 6250 all the way back and get about 5 minutes of flight time. My CG is probably about 5 mm behind the 120 mm book location. I use a 3 position switch for rates, with Ailerons at 14 mm deflection low to 25 mm high (book high is 20 mm) and expo of 45% (I use a lot of expo with my EDF's cause my fingers are not very steady and at minimal deflection, with that much expo, it's like it is in low rates but when I need it, full deflection gets me there, but that's just me). With a lot of expo, it seems to fly smoother without quick erratic changes. On Elevator, I'm at 17 mm to 26 mm (again higher than book) with 40% expo. Rudder is 25 mm to 34 mm, also more, but that is so it will knife edge for me better. On flaps, I use less than the book values, 25 mm take-off and 40 mm landing, with up elevator compensation of -3% take-off and -6% landing flaps.
                                      I would also recommend, when you feel comfortable, but should try it on the 1st or 2nd flight, get enough altitude, deploy flaps and slow it down while easing in elevator until it gets nose up and stalls. This will give you a feel on landing just how slow you can go and the speed you will need to land with jet not loosing altitude, or just a bit of altitude, while keeping the nose up for a nice 2 point landing on the mains. It will probably dip a wing to the left, which you can correct with aileron and then let the nose drop and give it some throttle to pull out. If you want to keep it in high alpha, just give it a little throttle and keep correcting the wing dips, either left or right, and it will fly around nicely it that high alpha position.
                                      Enjoy these EDF's and let us know how it goes.
                                      • Blhollo2
                                        • Nov 2020
                                        Anyone know what the top speed is of the high Performance version
                                        • SocksnSandals
                                          • Feb 2020
                                          Maidened my Stinger 90mm today. VERY stable. I'm using an AR636 receiver mounted sideways on the side of the battery bay near the rear. Even in low rates (60%) I found the roll too aggressive on the first flight. I dropped the linkage for the ailerons one hole at the servo (Thanks RC Informer) and turned my low rates down to 40%) to calm her down. She lands super fine although on my second flight I managed to set her down too close to the weeds near the curb, spun and snapped the front strut connecting pin. Dammit. My bad for sure! But as a bonus, I found that the strut connecting pin is the same one used in the FW T-33, which I have several! Prior to today, the FW T-bird was my fav but now that I've flown the Stinger that may change. In two flights it's definitely grown on me!
