Your rudder is reversed. Go to your transmitter and reverse your rudder in it.
What brand of transmitter is it?. Can help you reverse the rudder if you do not know how.
At this point, I'm not sure which sport jet I like better, my Avanti or this Stinger. The Stinger does fly outstanding and even with the stock out-runner it's plenty fast for me and gives 4-5 minutes on the 6000mah. Not bad, and after replacing the servo connections with the locking 5 pins, it assemblies in a snap (something I hated before and occasionally pulled wires out of the connectors at the end of the day-and no blue box to worry about!). Glad it didn't get discontinued. I was thinking of not replacing it at first and instead going with the plain F-18 and building out the Royal Canadian Demo Team (although I did get the graphics already from Callie, purchase the receiver and afterburner for it) but that's going to have to wait till Christmas, in case Santa actually reads my wish list.
I've attached a photo of the manual if that helps. If I remember correctly (which is a long shot), I think the 2 main gear servos went into the outside 2 ports, labeled Synchronous cabin door control on the manual. The nose gear then would go into the middle port labeled Asynchronous cabin door. Then again, it could be just the opposite.
Good luck!
