View Post
I cycled my servos for about 5 minutes. My question is, one of the flap servos was just noticeably warm compared to all other servos. Not hot, but there was a slight warmth compared to all others...
Should I be concerned about this and ask for a replacement, or go with it since it is on the flaps and not a main control surface servo???
This is the first plane I have done this on so not sure where you draw the line here...
Thanks...
tired iron, how did you connect the esc wires? mine are also disconnected but i can't hole the esc connectors to plug the bullets inCurrently Fly: Durafly Spitfire MkVb, Eflite P47 1100mm, Parkzone FW190A-8, Parkzone SE5a, Dynam Tiger Moth, Eleven Hobby Bearcat, Parkzone Mosquito MKVI, Durafly Tundra
Unflyable: Durafly Sea Vixen, Parkzone T28 (In temporary storage in tree)
Retired: Hobbyzone Delta Ray 'Frankenplane'
Wanted: Freewing A4
Mine went together quick and easy last night, just like everyone else has said. No issues at all. Also figured out where those plastic pieces went before reading the posts here. It's all set up and ready to go, will get decals on tonight (going with the Navy scheme). Here's a pic of my RoaringTop 6S 5800 35C installed. CG is at 195mm, measured with wheels up, no ordnance, no hump, per the revised manual. Maiden on Saturday!1 PhotoPat
Pat,
That's great. Thanks for posting the pic. I'll be reedy with my RT 5800. Also may try a RT 5000 with a high C rating. The hump has really grown on me. I didn't like it at first but now I do.. I'll be humping. The drop tanks are HUGE! Was hoping to see more air to air missiles Probably won't fly with the drop tanks unless I can drop them . Magnet on / Magnet off
HawkCurrently flying: Twin 80mm A-10, 80mm F5, 80mm A6, 70mm Yak-130, 70mm F-16v2,90mm Stinger 90, 70mmRC Lander F9F, Flightline F7F TigerCat, Phoenix 46 size Tucano, Flyzone L-39
Originally posted by Boots Whirlygig View Post
HHNF I'm trying to picture your taxi test misshap. Are you saying it tips due to the tall and narrow gear spacing, and when the wingtip hits it then flipped over on its back? Or did it over-rotate as if the main gear are too close to the CG and rock back on its tail, breaking off the aft fuse? Mines still on the stupid brown truck.
Some A-4 mods and tips...
The Freewing A-10 nose wheels are 70mm compared to the stock 65mm ones, these are much better looking.
I just didn't like the look with both tanks on so...
I squeezed the end of the fueling tube so it would fit snug in the fuse...
The tail hook shouldn't be glues in like the instructions recommend because it would be in the way of the fan access panel screws and there's already a place to put screws in it...
Blacked out the exhaust...
- Likes 2
Mine is here but doubt it will fly this weekend. Hoping Irma goes way to the east and not up the middle of the state.My YouTube Videos https://www.youtube.com/channel/UCrz...4Q-xrOOtP2C-8w
- Likes 2
Godspeed to our Florida brothers. Praying for a right hook. My company HQ is in Deerfield Beach and they are scurrying to bat down the hatches.Currently flying: Twin 80mm A-10, 80mm F5, 80mm A6, 70mm Yak-130, 70mm F-16v2,90mm Stinger 90, 70mmRC Lander F9F, Flightline F7F TigerCat, Phoenix 46 size Tucano, Flyzone L-39
Originally posted by HellHathNoFury View PostHey Wayne.. Congrats..Nice field you fly from.. Best of both worlds.. Lucky you..Out of interest.. Did you have to trim any control surfaces on your maiden???
Originally posted by RCjetdude View Post
Wayne, how were the landings?
- Likes 2
