Originally posted by Rando
View Post
As for the flap servos, I haven't found a good way to remove them. I have 2 Cherokees and no luck getting the flap servo out on either. It appears the wing halves were glued together with the servo installed and there isn't a window in the foam to pull the plug through. Given how little I use flaps, I decided to just leave the factory servos. The aileron, rudder, and elevator servos have all been replaced. I also added a servo-saver on the nose gear steering push-rod. That should take some load off of the servo and steering tiller arm in case you have a landing that isn't perfect or are operating off of grass.
