RE: FMS F3A Olympus 1400mm (55") Wingspan - PNP
They are digital. The gear slop when touching the surfaces while power applied is not too good (the rudder for instance - the worst example - moved at least 1/4" each way with power applies to the servo). This is a combination of servo slop and servo arm hole fit with the pushrod. There is zero movement with the futaba and hi tech servos. (Better pushrod fit and much better gear mesh fit). The deadband with the servos on is close to zero. I think the deadband with the FMS servos was ok with the gear slop contributing to 95% of the movement (slop).
