To Couchbr
Neither the 4 or 5000 6s option will give you the increased flight time you can get with 2 3000mah 4s Admiral's.
For a while I flew mine with 2 3600mah 4s HRB batteries. They barely fit. Flight time was ten minutes. Sadly, the HRB's swelled after half a season and no longer fit. I no longer use HRB batteries.
If you are thinking of using a single 4 cell, you would need one with at least a 70C rating to match the performance of 2 4 cell batteries with a 35C rating on each one.
Out of curiosity, I tried putting two 4000mah 4 cells in the plane. No go. Doesn't fit. A 3000 and 4000mah do fit with room for CG adjustment. This would provide 7000mah capacity which should be good for 9+ minutes of mixed flying.
Bernie
Bernie
