Official Black Horse 2385mm A6M Zero thread
Im buying the Black Horse Models 93" giant scale zero, does anyone know how well a Zenoah G62 with a spring starter and pitts style muffler would fly it, and how well would it balance out and roughly the weight when finished. Also the P40 aswell the same questions .
THANKSComment
Has any one had trouble with retract control box? I put power to box, plugged in a retract and hit test, nothing.. I tried both plugs and even hooked rx to it and tried retract sw on tx, got nothing. I want to also lighten spring on retract, as it seems way to stiff. Any help here?
Thanks RickComment
Do you have pictures of the setup? I assume you have plugged things into the proper ports? Does the blue light come on when you power it? Obviously the box could be broken, but also maybe the wire that you plug the power into has a bad solder joint.Has any one had trouble with retract control box? I put power to box, plugged in a retract and hit test, nothing.. I tried both plugs and even hooked rx to it and tried retract sw on tx, got nothing. I want to also lighten spring on retract, as it seems way to stiff. Any help here?
Thanks Rick
Could be a number of things that might be fixable, share more info and some pics.Comment
I finished my Blackhorse Zero today. I made the settings for all functions like it is written in the manual. Have somebody an experience. The second question is the Flap settings.
Is there a trim change necessary for half and full Flaps. Thanks for help PeterComment
Hello weiss.peter014@gmail.com and welcome to Hobby Squawk. I didn't add any sort of flap to elevator mix in mine. She slows down really well, so at the speeds I have been dropping flaps I noticed no ballooning or anything.I finished my Blackhorse Zero today. I made the settings for all functions like it is written in the manual. Have somebody an experience. The second question is the Flap settings.
I still have the model at the published CG and have a small amount of elevator/flap compensation, 1.5mm at full flap and it lands very level, almost hand free. The amount will change with the CG position and how much flap deflection you have. I altered the flap linkages to get more flap throw on mine.
James suggestion to check the input power lead is worthwhile. I recall resoldering mine to the plug as it looked a bit crappy.
The landing gear strut springs are fairly stiff, I prefer that to being too soft, mine is a little heavier with the Saito90. I haven't done it yet but will be fitting a nylon spacer to preload the springs to stop the clattering the gears make when taxying.Comment
Hello)
Just bought the BH Zero ... first huge and first gas project. I’m looking to put in the Saito 5 cyl/75 .. reason I bought the plane. I have heard that this set up has been done, but that the prop/spindle stick pretty far out. Does anyone know of this has been overcome? Can it be? .. otherwise, I’m looking at the Saito 90.
Any help greatly appreciated))
tomComment
The Saito FG73 R5 fits great with a ring-muffer and has enough power for the Zero.
Spinner an prob are a minimum to long but you can use this part to mount the Saito:
Viele Grüße
DennisComment
