I ended up going scale (outward turning props).
Official Nexa 2108mm P-38 Lightning ARF Thread
Anytime! At least I got that right. LOLMy YouTube RC videos:
Hi Aros,
Solved the issue with the cockpit by making two cuts which made it possible to follow the shape of the wing. Than filled it again with epoxy glue. Still have to finish it with some paint.
Two questions left...
Do you use the five plastic bolts or did you replace them with metal ones?
When I fully extend the flaps It’s still possible to partly move them back and forth. Where you able to reduce the play? If so, what did you do? 😃
Thanks!
Best regards,
Stan1 Photo
Good thinking on the two cuts to mold to shape. I recall using the plastic bolts. As for flaps I'm afraid you're on your own with that one. This model is notorious for it's fowler flap system that leaves a lot of play no matter what you do. It drove me and my builder absolutely nuts and we finally had to throw up the white flag and just live with it. If you find a solution by all means post it here for others with the model.My YouTube RC videos:
Thanks, yeah I came in hot as it was just my second flight and I was petrified to get her too slow, lol. Later flights I was able to bring her in much more scale. Truly a great flyer.My YouTube RC videos:
I'm sorry Ron I can't recall what servos we ended up using for the flaps. If I can find that info I will be sure to let you know.My YouTube RC videos:
I came across my itemized list of my complete setup...Here you go:
2x Dualsky 470Kv motors
2x Master Airscrew 16x10x3 counter rotating props (rounded tips down to 15.5")
2x Castle Edge 100A ESCs
20A Pro Amp BEC
Spektrum AR9020 9ch rx
Spektrum DX9 tx
HS-5485HB servos for ail, elev and rudder
HS-77BB servos for flaps
Detrum 9g servos for main gear doors
HS-55 servo for nose gear door
JR MatchBox Servo Matching/Power System
2x Robart #670 1/2" dia Straight RoboStrut (main struts)
#663L 7/16" dia LH Offset RoboStrut 3 3/4" - 4" (nose strut)
630RSE 90 Degree HD Mains RoboStrut Electric 24LB (electric retract system)My YouTube RC videos:
