F6F Hellcat 1535mm (60.4") Wingspan - ARF from Nexa - NXA1010-001
The F6F made its combat debut in September 1943, and was best known for its role as a rugged, well-designed carrier fighter, which was able to outperform the A6M Zero and help secure air superiority over the Pacific theater. A total of 12,275 were built in just over two years. Hellcats were credited with destroying a total of 5,223 enemy aircraft while in service with the U.S. Navy, U.S. Marine Corps, and Royal Navy Fleet Air Arm. This was more than any other Allied naval aircraft. Postwar, the Hellcat was phased out of front-line service, but remained in service as late as 1954 as a night fighter.
The Nexa F6F Hellcat is a .50 size electric or gas option scale series warbird with a 1570mm wingspan, constructed primarily from balsa wood and covered with a fuel-resistant covering. This ARF requires assembly and installation of your choice of servos and power system, and includes flaps, painted pilot, machine gun, antenna and other scale details. The large battery hatch affords ample room for either electric or gas setups. To complete the scale appeal of this beautiful F6F, the model includes electric retracts and scale struts. Impress at your flying field with this iconic stunner!
Fully Covered and Detailed The Nexa F6F Hellcat comes fully covered including simulated panel lines, rivets, nomenclature and weathering detail. |
| Scale Details Throughout There is no shortage of scale details with this F6F including functional flaps, antenna, machine guns, painted pilot, electric retracts and metal main struts. |
Prehinged and Installed Control Surfaces All control surfaces come out of the box fully prehinged and installed for your convenience. |
| Large Battery Hatch The F6F has a large battery hatch area to fit an array of LiPo battery sizes. |
- Complete Balsa and lite-ply construction for rigidity and durability
- Covered from tip to tail in scale details including weathering, functional split flaps, printed simulated panel lines and rivets
- Fiberglass cowling for strength and durability
- The hand-painted pilot is ready for your added cockpit details
- All control surfaces come out of the box pre-hinged and installed for convenience
- Large battery hatch allows for your chosen electric or gas setup
- Nexa F6F Hellcat 1535mm (60.4") Wingspan - ARF
- Electric retracts, wheels and struts
- Fuel tank, hardware and servo trays
- 7 Channel radio - select a minimum 7 channel radio from our Radio Collection
- 7 Channel receiver - select a minimum 7 channel receiver from our Receiver Collection
- Brushless outrunner motor - we recommend the Admiral GP10 5030-400kV Brushless Motor
- 65 Amp brushless ESC - we recommend the ZTW Mantis 65A ESC with 5A SBEC
- 4x standard servos for ailerons, elevator and rudder - we recommend the Hitec HS-485HB Deluxe Ball Bearing Karbonite Gear Standard Servo Airplane Multi-Pack (4 Servos)
- 4x standard servos for flaps - we recommend Hitec HS-85BB High Torque Micro Servo Airplane Multi-Pack (4 Servos)
- 6 Cell 22.2V 4000 mAh LiPo Battery - we recommend the Admiral 4000mAh 6S 22.2V 40C LiPo Battery with XT60 Connector
- Electric propeller - we recommend the APC 15x8 Thin Electric Propeller - Black
- 2 stroke engine - we recommend the NGH GT17 17cc Two-Stroke Engine
- 2 blade gas propeller - we recommend the APC 15x8 Gas Propeller
Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine).
PRODUCT SPECIFICATIONS:
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 6+ HOURS
| Model Scale | 1/9 |
| Wingspan | 1535mm / 60.4in |
| Length | 1130mm / 44.4in |
| Weight | 3500g / 123.4oz |
| CG (Center of Gravity) | 92-96mm from the leading edge of the wing's root |
| Power System | 400kV Brushless outrunner motor for electric or 2-stroke for gas (required) |
| Electronic Speed Control | 65A (required) |
| Propeller / EDF | 15x8 2-blade for electric or 15x8 gas 2-blade for gas (required) |
| Servos | 45g metal gear standard: left aileron, right aileron, elevator, rudder 17g metal gear standard: left flap, right flap |
| Landing Gear | Electric retractable (included) |
| Required Battery | 6 Cell 22.2V 4000 mAh LiPo Battery (required) |
| Required Radio | 7+ Channel (required) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | Yes |
| Lights | No |
| Hinge Type | Nylon |
| Material | Balsa and light plywood |
| Skill Level | Intermediate |
| Build Time | 6+ Hours |
