Freewing Mosquito
  • T.J
    Hobby Squawk Pilot
    • 25
    Ron 1950 Dropped you 100 years Sorry TJ
    • Ron1950
      Retired ATC
      • Oct 2015
      • 887
      • brandon ms
      no problem TJ I feel like I was born in 1850 anyway;;;)
      • Dewey H Lee
        WARBIRD JUNKIE
        • Apr 2015
        • 919
        • Fayetteville NC. US
        Hey Ron
        They all look bad when it first happens but when you pick up the pieces and look at them you say I can fix this. Give it a try. Bet it'll fly like you want when your finished.
        Dewey l
          Originally posted by Dewey H Lee
          Hey Ron
          Exactly! Matter of fact I would be interested in buying it if you don't want to fix it.
          • Dewey H Lee
            WARBIRD JUNKIE
            • Apr 2015
            • 919
            Your on to something there Tired Leon. From the picture there's potential there.
            Dewey l
            • Dewey H Lee
              WARBIRD JUNKIE
              • Apr 2015
              • 919
              Sorry my phone screws with what I type ALOT😨!!!!*******!!!!*.
              Dewey l
                That's ok, I don't read good anyway ;)
                • Ron1950
                  Retired ATC
                  • Oct 2015
                  • 887
                  • brandon ms
                  sorry guys gave it to a friend ...he put what was left back together and all the darn servos worked normal...hard to figure what happened in the air....
                  • Dewey H Lee
                    WARBIRD JUNKIE
                    • Apr 2015
                    • 919
                    Hey Ron.
                    I don't know but just reading over your post again I happen to notice that you said you were on a down wind left turn. I was curious to know if you were in the power or just taking it easy since it was a maiden. Because it sounds like a stall which I've had happen to me turning back into the wind. Slot of the other guys have more years under there belt than me and so maybe they'll chim in. When it happened to me I was lucky and it was a last second save coming within 2feet of the deck. I was maybe 100 feet up and thought something had quit until one of the older guy's explained what happened. Just a thought.
                    Dewey l
                    • Ron1950
                      Retired ATC
                      • Oct 2015
                      • 887
                      • brandon ms
                      dewey I was full throttle it just never turned back out of the turn
                      • Dewey H Lee
                        WARBIRD JUNKIE
                        • Apr 2015
                        • 919
                        Wow man I'm sorry. It's tough when you don't have a clue. I was just throwing it out there because of what happened to me. Whatcha gonna replace it with. Have to fly man to keep the withdrawals away.😨😁.
                        Dewey l
                        • Ron1950
                          Retired ATC
                          • Oct 2015
                          • 887
                          • brandon ms
                          got a quick questions for all you guys....my mossy took off got to about 30 feet and I turned left for the downwind....it never came out of the turn and spun in...now I gave the wreck to a friend after taking out the rx...he put it back together and flew it for a flight...all servos worked etc....now what could have been wrong with my flight? reciver brown out? any suggestions? and no I didn't take one red wire off one of the esc's...thanks
                          • Flygirl
                            • 969
                            • Glen Burnie, Maryland USA
                            Kind of sounds like a stall Ron... Slow speed from take off, left turn to downwind so you take the wind speed and subtract it from your airspeed coupled with possible high angle of attack. Could have been a tip stall?
                            Lauren
                              Hello Ron,
                              I emboldened one of your comments because since you are still reaching out for a possible cause to your maiden misfortune this is the most likely cause.
                              As an experienced pilot of many electric twins, the removal of one of the ESC's BEC red wire's(wire that plugs into Rx) is the golden standard. The reason for doing this is so that the two BEC's don't fight for control over what voltage to provide to the system(Rx). The majority of the newer 30amp and up ESC's are switching versus linear devices. The linear device would get the system voltage via voltage reduction which generates heat and thusly used on 3S or less setups and are tolerant to the BEC's running in parallel. ESC's that are running 4S and higher voltages are usually switching BEC configuration in the 30amp and higher range. The switching allows the BEC to do the reduction from the 4S(16V) down to the system Rx voltage of 5V without a lot of wasted energy via heat, unfortunately the switching devices don't play well together when Y'd together.
                              My suspicion is that the port ESC at full throttle(max current demands) became unstable due to the two BEC's fighting each other and caused a power loss or reduction of power to the port motor which just exasperated the situation you where unfortunately in due to the left hand turn. Most experienced twin pilots know that dead stick(no motor power) is the better option than trying to overcome imbalanced power. I'm guessing that your not an experienced pilot for twins based upon your comment back in post #10.
                              My comment earlier on the golden standard of removing the red wire on one of the BEC leads can also be confirmed on RCINFORMER's video for this aircraft at the 55min-15sec mark. This video is on MotionRC's product videos for the Freewing Mosquito at this link....
                              Hope that I've helped bring some insight to twin operation and a little closure to your loss.
                              Best regards,
                              • Ron1950
                                Retired ATC
                                • Oct 2015
                                • 887
                                • brandon ms
                                OV10 thanks I thought pretty much the same thing until the rebuild and still no red wire removed and the darn plane flew fine all flight...it looked like hell but flew pretty good...
                                • Icarus the 2nd
                                  • Aug 2018
                                  • 164
                                  • Pajottenland, Belgium
                                  Here's a whole uncut flight I did today with my Freewing Mosquito. Still going strong since 2016 and big fun to fly. Too bad the plane was discontinued ...
                                  Enjoy the whole flight and watch till the end for the silky-smooth landing
                                  • Skosh25
                                    • Mar 2019
                                    • 177
                                    • Denver
                                    Man, I'd love a V2 Mossie. Well done!
                                    • Beeg
                                      • 1335
                                      • Texas
                                      Yes! A new 1500-1600mm Mossie would be a must have.
                                        Yep, need a new Mossy. My old PZ is still flying strong, but well worn.
                                          I'd love a new mossy, being a freewing would be even sweeter, or nexa :)
