FMS P-40B Warhawk Flying Tiger 1400mm
  • #21
    Now that's interesting. My first flight I used a 4000 4s with it all the way forward and found it to be pretty good, I backed it back to the inboard battery strap but haven't tried it yet, now you guys are suggesting even further back, which is great as it gives me even more room to experiment. Thanks
    • #22
      With the 4S 4000, the forward battery strap just barely wraps around the end of the pack. I bet you'll find she behaves a little better. And don't forget to remove a little up trim. ;)
      • #23
        Did you mix any up elevator in with your flaps?
        • #24
          Not on mine. She seems to have no ballooning with flaps. It feels very locked in on the decent to landing.
          • #25
            Gotcha, I'll give it a try!
            • #26
              As the weather was being uncooperative yesterday, I started doing rivet detail on the P40. I have a small plastic ruler with cm increments on it, so I spaced my 'rivets' 1/2 cm apart and it looks good. You can increase the size of the rivets by inserting the pin further but I went pretty subtle on it and it looks great. It's one of those details that your not going to notice from ten feet away, but as you get closer, it a oh wow kind of moment. One other thing I did that's so simple is to add the front sight as well. I took a toothpick and cut it and painted it black and voila, looks perfect! don't know why they didn't do that from the factory with a plastic piece, but whatever. Also used testors chrome paint on the back of the wheels and the grey parts of the struts, then painted the rims around the hubs as well, generally cleans it up.
              • #27
                I've wondered why the rear sight is offset to the right. Anyone know?
                CR
                • #28
                  I'm not sure, but it was that way on the real ones as well, strange. It might have something to do with the air intake getting in the way of the sights.
                  • #29
                    Anyone tried 5500's?
                    • #30
                      Hey all. Can someone tell me the diameter of the spinner plate that the prop screws on to. Trying to see if it would work on the durafly p-40n since the replacement spinners are never coming back in stock. Thanks in advance
                      • #31
                        Just measured a spare spinner I have, 3 5/16 inches outside to outside.
                        Has anyone ever modded the tail wheel doors to retract by pushing a spring like the Tigercat and the Avanti do?? I'm just trying to find a spring that works. Ever notice how few small springs we have in 'normal' life??
                        • #32
                          Dan......remember me doing that Tigercat door setup to the 1500 Razors tail doors? Looks like the same can be done to the Warhawk with about a 1.5 inch ball point pen spring.
                          • #33
                            I'll try that CB, it's a much better method than the spring setup from the factory.
                            • #34
                              Just received mine from motion Tuesday and and sure was a breeze to put together, they seem to have stepped up the quality in the hinges and control rods from previous fms models.
                              i have quite a fleet of fms stuff now and I really like how they fly.
                              • #35
                                Rrman, you'll love this plane! It's even better with a 6s system, but is no slacker in the stock config either.
                                • #36
                                  Hi guys, as soon as this virus “stay in home” is lifted, I’m gonna maiden my new P40b. Is everyone still happy with the Admiral 4000 just at the first battery Velcro? Just barely covering the ring hole? Thanks
                                  • #37
                                    Yeah, I hear you, I got rid of the yellow pupils in the eyes as well, and I agree that the slant isn't enough, they're almost vertical!
                                    The one thing I really didn't like was the Tiger emblem, they got that wrong. I had Callie make me new ones that are much more accurate as you can see from the before and after picture.
                                    As for the stock ESC, from the spare parts page, it will handle a 5s battery, so I'm thinking that route as well.
                                    Wow, I didn’t even notice the tiger but you’re right on that color. Yuck. I’ll get Callie to make me up some. She made my wheel covers for me.
                                    • #38
                                      I wrecked my P40 in a tree last year and it finally came down but the multi connector is not working! The one I received from Horizon Hobby was not correct, anyone have any suggestions???
