The Fokker DR.1, famously flown by the Red Baron, is one of the most iconic aircraft of World War I. Known as the "Dreidecker" for its distinctive tri-wing design, this historic fighter dominated the skies with its agility, power, and innovative engineering. The Nexa Fokker DR.1 captures the essence of this legendary aircraft with exceptional scale detail and versatile power options.
With a commanding wingspan of 1850mm (72.8”), the Nexa Fokker DR.1 ARF is expertly crafted from lightweight balsa and lite-ply, offering both durability and performance. Its stunning weathered finishes bring this historic aircraft to life, while scale details like the fiberglass cowling, WWI-style wheels, realistic machine gun, and painted pilot make it a showstopper at any flying field. Designed to accommodate 25–33cc gas engines, 140-size nitro engines, or equivalent electric power setups—this model delivers versatility and unmatched scale realism for an unforgettable flying experience.
Whether you’re a devoted warbird enthusiast or seeking a standout addition to your collection, the Nexa Fokker DR.1 masterfully blends the timeless allure of WWI aviation with modern engineering and performance.
Iconic WWI Scale Details Complete with a detailed machine gun, vintage-style wheels, and a hand-painted pilot, this model brings history to life with unmatched authenticity. |
Exceptional Build Quality Crafted with precision, the fiberglass cowling adds durability and strength, perfectly complementing the robust balsa and lite-ply construction of this iconic tri-wing fighter. |
Vivid, Historic Color Schemes Choose from two striking WWI-inspired paint schemes that capture the essence of the legendary Fokker DR.1, ensuring it stands out both on the ground and in the air. |
Pre-Hinged Control Surfaces Factory-hinged control surfaces save time and ensure precise alignment for a smooth and effortless build. |
- Lightweight balsa and lite-ply construction for durability and optimal performance
- Stunning finish for a realistic and authentic look
- Scale WWI machine gun, wheels, and painted pilot for added realism
- Control surfaces pre-hinged and factory-installed for easy assembly
- Wide range of power options: nitro, gas, and electric compatibility
- Large, two-piece wings for easier transportation and storage
- Spacious fuselage compartment for convenient radio and power system installation
- Fiberglass cowling for durability and scale accuracy
- Includes fuel tank, aluminum wing joiner, and decals for easy customization
- High-quality hardware package for reliability and ease of assembly
- Detailed assembly manual for straightforward setup
- Nexa Fokker Dr1 Red Baron 1850mm (72.8") Wingspan - ARF
- Fuel tank and complete hardware set
- Decals and detailed assembly and instruction manual
- 6 Channel radio - select a minimum 6 channel radio from our Radio Collection
- 6 Channel receiver - select a minimum 6 channel receiver from our Receiver Collection
- 10S power system - we recommend Admiral GP26 6330-245Kv Brushless Motor
- 120 Amp Brushless ESC - we recommend ZTW Skyhawk 130A ESC High Voltage with 10A SBEC
- 6x high torque servos - we recommend 6 Hitec HS-5085MG Digital Metal Gear Micro Servos
- For 10S setup - we recommend Admiral Pro 6000mAh 5S 18.5V 50C LiPo Battery with EC5 Connector Multi-Pack (2 Batteries) in series for 10S
- EC5 2-to-1 series adapter - BenchCraft EC5 2 to 1 Series Adapter with 10 Gauge Silicone Wire
- 5 Cell compatible battery charger - select a minimum 5 or 6 cell charger from our Charger Collection
- 4 stroke engine - we recommend the NGH GF30 30cc Four-Stroke Engine
- 2 blade gas propeller - we recommend the APC 16x10 Gas Propeller
Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
AGE LEVEL :14 and up
SKILL LEVEL :intermediate
BUILD TIME :8+ hours
| Model Scale | 1/3.8 |
| Wingspan | 1850mm / 72.8in |
| Length | 1420mm / 55.9in |
| Weight | 7.4-7.8 kg / 16.3-17.2 lbs |
| CG (Center of Gravity) | 110mm from the leading edge of the top wing |
| Power System | 25cc (2-stroke) to 33cc (4-stroke) gas / equivalent electric (required) |
| Electronic Speed Control | 120A (required for electric) |
| Propeller / EDF | 16x8 – 17x10 (gas) – 18x10 (electric) (required) |
| Servos |
| Landing Gear | Fixed Gear (included) |
| Required Battery | 8S-12S depending on the electric power system installed (required) |
| Required Radio | 8 Channel (required) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | No |
| Lights | No |
| Hinge Type | Nylon Heavy Duty pin hinges |
| Material | Balsa and Plywood |
| Skill Level | Intermediate |
| Build Time | 8+ Hours |
Visit the Official Nexa Fokker Dr1 1850mm ARF Discussion Thread on HobbySquawk.com for additional photos, videos, reviews, and customer Q&A.
