  • Beetlemankurt
    • Aug 2018
    • 124
    • Rotorua, New Zealand
    Cheers LB. yours looks great! Very nicely detailed. Any tips or trick you learnt during the install? Any foam need carving? Looks like it fits straight in from your pics. I like the pilot, I’ll definitely be getting an Aces of Iron one.
    Cheers BMK.
      • 4825
      Cheers BMK.
      BMK, Thanks. I do not recall 'any' fit issues. I always 'black base/prime' my parts, other than that it's straightforward. Post pictures of your progress. Best, LB
      • Beetlemankurt
        • Aug 2018
        • 124
        Just a bit of an update on the cockpit kit. Managed to splash a bit of paint on over the last couple of days when I’ve had a few spare minutes. Far from done yet but getting there.
        Have added some more details out of foam and some wire from spare servo leads as seen in the first photo to add a bit more detail after looking at some reference photos. Not sure how much of it will actually be seen when installed but I’ll know it’s there! 😂...will most some more as things progress. So far it’s been fun 😁.
        cheers BMK.
          Nice paintwork and extra detailing, BMK! Very sharp.
          • Beetlemankurt
            • Aug 2018
            • 124
            Cheers Alpha, it’s getting there bit by bit. Quite a satisfying little project putting all of this together :).....
            Regards BMK
            • miatateer
              • 33
              • Fredericksburg, VA
              Isn't it curious how we spend so much time adding these lovely little details knowing full well that a crash is in our future? 🙄 😏 But boy, am I having fun adding those details!
                • 4825
                MT, Well written. It is the inevitability that motivates some of the work as long as you have pictures before the 1st Check Flight. Best, LB
                • RRHandy
                  Instructor Pilot
                  • 892
                  • Lilburn GA
                  Shhhhhhhhhhhhhhhhhhhhhhhhh, never say it.
                  AMA 424553
                  • Beetlemankurt
                    • Aug 2018
                    • 124
                    There’s two ‘C’ words that I won’t use.....and this is one of them! It’s a family show!........😂
                      • 2693
                      All I know is that if I ain't crashing, I ain't flying.
                      • boomer108
                        Chief Boom
                        • Apr 2014
                        • 867
                        • Chicago IL.
                        I flew with the Air Force for 23 years and we never used the "C" word when we flew superstition bad luck whatever we never used it. To this day I still don't. I like mishap.
                          • 2693
                          I like it, no more cr....ing, just mishaps. Like my wife says when I come home with my head down, "happens, now either fix it or replace it and get back out there cause I didn't marry no pus...y". Gotta love her, hope she doesn't find out I use that act even after a good day of flying so I can order a new plane when I get the "itch". She may be catching on though as each time a new plane arrives she looks at me and says "I don't remember seeing that one before" and I'm sure she's not buying the excuse that the planes are breeding as my hangar is busting at the seams. Although I know her dresses, purses and shoes must be breeding cause I no longer have any space in any closet so why not pregnant planes?
                            • 2693
                            I do know that in all my years of flying, I've never had a "mishap" caused by "pilot error", always a "mechanical malfunction ". The NTSB concluded that there was always an error in the mechanical movements of the transmitter sticks in the wrong direction. Darn those cheap electronics, sticks moving in the wrong direction. That's my story and I'm sticking to it.
                            • paladin
                              model customizer since 1968
                              • 243
                              i don't ever cr.... I personally customize!
                              • miatateer
                                • 33
                                So with all those lovely cockpit details and my "Aces of Iron" pilot all painstakingly painted, I see that my cockpit glass is really not that clear. Is it common for the clear plastic to have foggy blotches? I did try washing it, but that didn't help at all.
                                  • 4825
                                  MTT, Could be 'mold-release'. It's 'unclear' without a picture. Mineral Spirits is fairly benign on acetate sheet, but you might try that on a section you are going to paint, presuming you are repainting it. IPA should also remove mold release and it will not harm the clear parts at all in my experience. I have also used a pink metal polish called "Simichrome" to polish clear sheet as it is a very very light abrasive. I then rewash and check. Again try it first on under a painted part. Best, LB
                                  • Beeg
                                    • 1335
                                    • Texas
                                    Sounds like you have some chemical etching or deposits. Did you use CA glue close to the canopy or other harsh solvents? If so, as Elbee said you'd need to polished the plastic which would be hard unless you have a soft buffing wheel setup. Cheapest and easiest option would be to get a replacement canopy from Motion for 5 bucks.
                                    • Beetlemankurt
                                      • Aug 2018
                                      • 124
                                      Hey Miatateer, just to add to the list of possible solutions, I use Meguiars PlastX plastic polish on polycarbonate RC car bodies and plane canopies. Very mild abrasive polish designed to clear cloudy headlights and minor scratches from clear plastics. I put some on my Spitty canopy even though it was already pretty clear and it still brightened it up.
                                      Cheers
                                      Kurt
                                        In the past I have also had good success at times with dipping clear plastic parts in Future floor polish (or its modern equivalent).
                                        • miatateer
                                          • 33
                                          Thanks all! I will give some of these a try. Certainly isn't from CA fumes. I don't let that stuff anywhere near clear plastic. Came in the box with these foggy spots.
